Author Topic: Part number for metal gearknob clip?  (Read 1900 times)
Offline Wardy
    • Briskoda
« on: March 11, 2011, 01:06:21 pm »
Looking to swap them over, but can't see a way of getting the existing clip off in one piece, so I can replace it once the gearknob's been swapped.
Anyone got a part number for this, so I can get a new one in advance?
Thanks.
Offline 182_blue
  • -Receive: 54
Re: Part number for metal gearknob clip?
« Reply #1 on: March 11, 2011, 01:39:17 pm »
Do you mean the clip that holds the actual knob onto the stalk ?, if so it requires a special tool to put these clips back on, and of course a new clip, most people just use a cable tie.
« Last Edit: March 11, 2011, 01:44:19 pm by 182_blue »
Offline alexperkins
  • -Receive: 99
« Reply #2 on: March 11, 2011, 01:42:15 pm »
CV boot pliers  :grin:
Offline Jaywoo-GTI
  • -Given: 38
« Reply #3 on: March 11, 2011, 02:27:09 pm »
Stainless cable ties do a better job than the original
Offline alexperkins
  • -Receive: 99
« Reply #4 on: March 11, 2011, 02:28:24 pm »
They do a better job than most kinds of ties
Offline apollo13
  • -Receive: 47
« Reply #5 on: March 11, 2011, 03:54:51 pm »
I used a small jubilee clip  :happy2:
Offline Wardy
    • Briskoda
« Reply #6 on: March 11, 2011, 04:04:46 pm »
Thanks guys. Yes it is the clip that holds the base of the knob to the shaft  :wink:
No wonder I have trouble trying to remove it if you need special tools! It doesn't seem to have a join in it, so couldn't see how to expand it enough without ruining it.
Offline alexperkins
  • -Receive: 99
« Reply #7 on: March 11, 2011, 04:09:44 pm »
You can remove it with a screwdriver, though try not to damage it. You can close it back up with a pair of wire cutters  :happy2:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #8 on: March 11, 2011, 07:06:40 pm »
Before you remove the clip have you tried pulling the knob off first  :grin:?. When i changed mine on the last GTI just gave it a good pull & it came off  :innocent:. Worth trying first. :signLOL:
Offline Wardy
    • Briskoda
« Reply #9 on: March 28, 2011, 05:40:29 pm »
Cheers guys. I did try to remove it without touching the clip, but it wasn't for budging!
Have now tracked down a suitable clip I had lying about, so that should do the trick.
Thanks all,
Steve
