Author Topic: Replacement VAG electrical plugs  (Read 6125 times)
Offline gazbutS3
« on: March 12, 2011, 01:53:37 pm »
Does anybody know if its possible to buy replacement plugs for the fiddly little rascals that connect everything up on our cars. The brake pad wear indicator connection has broken on the wire side of the female side, I've bodged it for know but would like to replace it if possible :happy2:
Offline QD MBE
  • -Receive: 102
Re: Replacement VAG electrical plugs
« Reply #1 on: March 12, 2011, 01:55:34 pm »
« Reply #2 on: March 12, 2011, 02:00:01 pm »
thats a great page dave! been after than for years! :0
Offline gazbutS3
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: March 12, 2011, 03:23:37 pm »
Most plugs have the part number on them Gaz.
Getting the pins out can sometimes be in issue, I have a couple of the special tools but they aren't cheap.
Stu...
Offline gazbutS3
« Reply #5 on: March 12, 2011, 05:16:43 pm »
cheers Stu, the pins have rotted away :confused:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: March 12, 2011, 05:30:02 pm »
From the PN of the plug you can ascertain the numbers for the repair wires  :evilgrin:
Are you going to repair it yourself??
Stu...
Offline gazbutS3
« Reply #7 on: March 12, 2011, 06:18:33 pm »
think so, if not one of the sparks at work can help me :smiley:
so VAG sell repair wires to splice into the original loom?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #8 on: March 12, 2011, 09:11:26 pm »
So it's the car end Gaz and not the brake pad??
Stu...
Offline gazbutS3
« Reply #9 on: March 12, 2011, 11:57:43 pm »
yep
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #10 on: March 13, 2011, 10:52:48 am »
Gaz
The plug on the pads is 1J0 973 702
The plug on the car end is 1J0 973 802.  The suitable repair wires for this plug are 000 979 020 E.  You'll only need one as each wire has 2 terminals fitted.
Stu...
Offline gazbutS3
« Reply #11 on: March 13, 2011, 11:21:12 am »
cheers Stu, top man :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #12 on: March 13, 2011, 11:27:04 am »
They may tell you the wire has a superseded part number, they seem to be changing a few of the repair wires lately.
Stu...
Offline damoegan
« Reply #13 on: March 13, 2011, 07:26:20 pm »
I've got 4 of the D shaped plugs (including pins) if those are any good to you, Gaz?
Offline gazbutS3
« Reply #14 on: March 16, 2011, 09:20:35 pm »
thanx pal, only just seen your offer, have already ordered the bits, thanx anyway :happy2:
