Author Topic: unlocking not working on key?  (Read 2288 times)
Offline stevo
« on: March 12, 2011, 09:50:20 pm »
hi
only had my 05 golf gt a month and today it decided it wont unlock by the button on the key ? yet it will lock it fine
any ideas. been lookin at past troubleshooting topics but couldnt see anthing
thanks :happy2:
Offline pobmk4
Re: unlocking not working on key?
« Reply #1 on: March 13, 2011, 05:08:09 pm »
Try either recoding the remote, or if you have a spare key try it and see!? but if that fails and it still doesnt unlock you could be looking at broken wiring, faulty lock or even faulty door control module!! I'd try the easiest ones first!!!  :laugh:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #2 on: March 13, 2011, 05:49:36 pm »
Does the little red light on the remote flash when you hit the unlock button?  If so I think its most likely the door lock module unfortunately.  Checking the wiring in the door connector is a good idea, just in case.
Sepang Blue S4 BE Avant
Offline biilyb
« Reply #3 on: March 13, 2011, 06:07:47 pm »
 Hi
 Do you have a spare key try that. if not you could try and change the battery in the key costs 3 pound for the battery. if its not that it might be what the other guys have said. i have an 05 plate as well and the battery had gone
Offline dnLcal
« Reply #4 on: March 13, 2011, 07:28:39 pm »
I had it where when you pressed the button you could hear it trying to unlock but it wouldnt unlock the drivers door, but sometimes it would.
It turned out to be a faulty/worn lock motor which vw replaced under warranty.
Cal
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #5 on: March 13, 2011, 11:05:02 pm »
Cal
^^ This.  Its happening on mine, intermittent at the moment - works more often than not but on its way out.  From my research on it its reasonably common.  A new lock unit is about £175 plus fitting.  Total of £300 ish from VW but I think its within the scope of DIY if you're brave enough to take the skin off the outside of the door.
Offline stevo
« Reply #6 on: March 14, 2011, 08:18:27 pm »
thanks for the info changed the battery all sorted :happy2:
