Author Topic: High pressure aircon switch and headlight washer pump  (Read 14467 times)
Offline Phil Miller
  • -Given: 86
Re: High pressure aircon switch and headlight washer pump
« Reply #15 on: March 21, 2011, 09:49:22 pm »
cheers Phil i will do mate  :happy2:     dont suppose anyone knows the part no.?
the sensor part number is 1K0 959 126 B and they call it a thrust sensor and the O ring is part number 3D0 260 749 C and called a sealing washer  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=q242tqcc532rg4h63rr1tk9epo&/topic,19740.0.html
« Reply #16 on: March 21, 2011, 09:52:23 pm »
^ On my invoice is shows as  1K0 959 126 D... just make sure its the latest part revision!
Offline v2brett
« Reply #17 on: March 21, 2011, 09:55:50 pm »
cheers Guys  :happy2:   what would i do with out this place........... apart from have a full wallet  :signLOL:
Still Here!
Offline Phil Miller
  • -Given: 86
« Reply #18 on: March 21, 2011, 10:01:09 pm »
sorry should have added that my part number list is a little old now :sad1: the dealer will only supply the most up to date revision
MPS
« Reply #19 on: March 04, 2012, 09:33:01 pm »
Sorry for resurrecting an ancient thread, I have the same inoperative aircon problem, would a faulty high pressure switch throw a fault code up on Vagcom?
Matt
Offline micky 32
« Reply #20 on: March 04, 2012, 10:57:24 pm »
What is the symptom of one of these failing? I have intermittent aircon but no fault codes and gas is ok.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
Offline Gazza747
« Reply #21 on: March 05, 2012, 07:55:46 am »
My high pressure switch is faulty. All of the gas has leaked out so no cooling and all of the other symptoms that come with having no pressure or gas in the system.
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
