Author Topic: Engine out for cambelt?  (Read 2844 times)
Offline SteveS
« on: March 15, 2011, 07:41:13 pm »
Do they take the engine out for cambelt?
Im going to have it done thursday, im thinking they are going to have some issue with my intake and the heat shield
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Re: Engine out for cambelt?
« Reply #1 on: March 15, 2011, 07:47:59 pm »
 :signLOL: NO
Offline SteveS
« Reply #2 on: March 15, 2011, 07:51:23 pm »
google search showed some threads which said they do
SOLD!! :(
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=j3lijlstoqd3efbtj1r2ila01i&/topic,19740.0.html
« Reply #3 on: March 15, 2011, 08:02:04 pm »
If they had to take the engine out it would be a dam sight more than 400quid
Offline SteveS
« Reply #4 on: March 15, 2011, 08:22:41 pm »
true, but to replace the engine mounts they kinda lift the engine out a tad but that doesnt cost
SOLD!! :(
Offline MattPoss
« Reply #5 on: March 15, 2011, 09:05:29 pm »
It's much easier to lift the engine up in order to get at it, it's quite tight by the cambelt.
Mines getting it done this weekend and my mate rekons it's easier and quicker to lift the engine and remove the driveshafts aswell to stop them getting damaged. He works in the dealers and that's how they do them.
Matt
« Last Edit: March 15, 2011, 09:18:08 pm by MattPoss »
Offline alexperkins
  • -Receive: 98
« Reply #6 on: March 15, 2011, 09:48:54 pm »
Interesting that dealers remove the driveshafts, when the official VW manual doesnt state to do that. It merely says remove the pendulum bracket, support the engine, remove the upper engine bracket bolts and lift engine slightly with the 'support bracket' tool they detail.
Offline MattPoss
« Reply #7 on: March 15, 2011, 09:53:58 pm »
My mate says it's not necessary but he does it as a precaution, says he's seen a few damaged during lifting the engine and he'd rather take out 12 bolts (I think) than risk it.
Matt
Offline alexperkins
  • -Receive: 98
« Reply #8 on: March 15, 2011, 09:54:56 pm »
Thats a fair point
That could well explain why my driveshaft bolts have been undone as the cambelt was done relatively recently.
Offline SteveS
« Reply #9 on: March 15, 2011, 09:55:35 pm »
no doubt my dealer will f*ck it right up
SOLD!! :(
Offline Boothy
  • All donations accepted, thanks.
« Reply #10 on: March 15, 2011, 09:56:00 pm »
On my 05 model the cambelt cover wad one piece with the engine mount running through the middle so the engine had to come out slightly. To save costs the garage just chopped the cover in half and replaced it with the newer, two piece cover.
Offline MattPoss
« Reply #11 on: March 15, 2011, 09:57:23 pm »
Try a different dealers if there's another one not too far away, sounds like you don't have much faith in them judging from a few threads you've posted in
Matt
Offline SteveS
« Reply #12 on: March 15, 2011, 09:58:00 pm »
nail \ head
SOLD!! :(
Offline vRSAlex
  • -Receive: 253
« Reply #13 on: March 15, 2011, 10:59:50 pm »
Some garages do some odd things that you just dont need to do.  No need to remove engine, undo driveshafts or even cut up the one piece cover (which i thought was the newer version?).
The engine does need to be raised on one side slightly, but not enough to cause driveshaft issues.  This is just to get the mount removed from the block.
Why do you have to go to a dealer?  There are loads of specialists that will be far more experienced than any dealer and take much more care.
Follow AKS tuning on Facebook
Offline SteveS
« Reply #14 on: March 15, 2011, 11:03:48 pm »
I have a service plan, so unfortunately yes i do.
If there was another one within distance id use it
SOLD!! :(
