Author Topic: VEry quick one...CANBUS gateway query.  (Read 1257 times)
Offline johnhol78
« on: March 16, 2011, 03:25:06 pm »
Right my sisters just bought a 57 plate GT Sport and she has a RCD300 in it.
If the gateway on this is newer than L it would be ok for the battery drain issue....I know that.
But could I swap gateways over with my one? She doesn;t need to worry about the drain issue as she has the 300 while I just bought a 310.
Would they both need coding - if they weren't waht issues would occur?
Offline alexperkins
  • -Receive: 99
Re: VEry quick one...CANBUS gateway query.
« Reply #1 on: March 16, 2011, 03:26:28 pm »
It needs to be K or newer generally speaking to get around the battery drain issue
They would both need coding as every car has a different set of options in most cases, if you didnt alot of things could stop working or reporting incorrect information.
Offline johnhol78
« Reply #2 on: March 16, 2011, 03:31:34 pm »
Thoguht so......oh well...need someone local with the coding experience....
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #3 on: March 16, 2011, 03:56:16 pm »
Use VCDS and make screendumps of the install list of each gateway install list, then it's a walk in the park  :happy2:
Over the top mod list ;o)
