Author Topic: Need to buy oil for GTI - should I buy longlife if on T & D  (Read 1384 times)
Offline CaptainJack
« on: March 16, 2011, 11:00:37 pm »
Just wanted to double check. Also, is it more expensive getting direct from VW as they're just down the road.
Re: Need to buy oil for GTI - should I buy longlife if on T & D
« Reply #1 on: March 16, 2011, 11:04:06 pm »
You want longlife oil regardless of service schedule...
Offline alexperkins
  • -Receive: 99
« Reply #2 on: March 16, 2011, 11:04:41 pm »
I run my ED30 on T&D and continue to use Longlife III oil as this seems to be the generally recommended way forward as its a better quality oil than what VW recommend using on T&D
And yes, VW are quite pricy for it. If you have a TPS nearby, you can get exactly the same stuff from them for dramatically less.
Offline CaptainJack
« Reply #3 on: March 16, 2011, 11:06:48 pm »
Ok..cheers for the answers lads
hugh jass
« Reply #4 on: March 16, 2011, 11:16:30 pm »
 VW Quantum oil is what you want, 507 spec. Dealers will charge around £27 for 4 litres IIRC.Ask for a new filter/sump plug at the same time and get a discount
 There are lots of oils which are 507 such as Comma,Fuchs,Valvoline,castrol.
 Doesnt matter if your on T&D or Longlife 507 is the one for you.
        There is a lot of debate as to weather Longlife is good for the engine. I wouldnt like to leave oil in for up to 20000 miles
           10000 miles = new oil and filter :happy2:
  • -Receive: 291
« Reply #5 on: March 16, 2011, 11:39:58 pm »
:stupid:
507 is for diesels. You want 504 standard. Must be approved to VW504. Must have the "approved" and "504" bit.
You want 5W-30 spec oil.
hugh jass
« Reply #6 on: March 16, 2011, 11:50:35 pm »
:stupid:
Yes your right.   :confused:In my mind Im still living with the Sootpig :confused:  I only changed a month ago. :stupid:
Offline Dario
  • booosting... :)
« Reply #7 on: March 17, 2011, 12:21:02 am »
I have been using Longlife III  from day one ,couple of TDs ,and not a problem with oil ,but I do change it every 5000-7500 km
REVO ST2+ Edition30 -sold
soon 2015 Golf R :)
