Author Topic: HELPPPPP what alloys should i get?  (Read 2698 times)
Re: HELPPPPP what alloys should i get?
« Reply #15 on: March 17, 2011, 08:29:25 pm »
thanks for your replies guys! i only put these ones up for the style to see what everyone thought. my golf mk5 is black and what ever alloy io get in getting some rim protectors in red to go with the red grille at the front. am i correct in saying i need alloys with 5 stud, 112 pcd, 42-50 offset and a cb of 57.1 as stated above? wanting either 18's or 19's thanks
Also remember that you with a 7" wide alloy you will want around a 45-51 (51 is standard) offset and the wider you go, the lower the offset will need to be to balance the outer rim with the inner rim. :smiley:
Don't go near anything that is wider than 8.5" and even then you may get rubbing if you are lowered.
Offline harryralston
« Reply #16 on: March 17, 2011, 09:36:20 pm »
its just what im looking for but cant find any good one. want them in black with the red ring. just dont want to order them and then find out they dont fit! thanks
Offline Five Alive
« Reply #17 on: March 17, 2011, 09:44:26 pm »
