Author Topic: Advice needed regarding CAI  (Read 4544 times)
Offline donovan2123
« on: March 17, 2011, 09:28:30 am »
Hi, I own vrs 2.0t and need some advice im currently running stage 1 map which seems good. I did a few logs and it seems that car is overfuelling abit high end of rev range and engine is pulling timing back because of this. I considered a fuel pump but after logs it was evident this was not need and if anything a CAI is needed to allow map to perform at best. So my question to you is what kit should I get to give more flow all round bearing in mind price as forge is very expensive to me. My flow maf was peak 190g/s. Which I been told is prob equivelant to around 230-235bhp max using calculation, MAF value, divided by 0.81= the rough Hp @ any point.
Offline edd666999
  • -Receive: 89
Re: Advice needed regarding CAI
« Reply #1 on: March 17, 2011, 09:29:08 am »
who's map are you running?
Offline donovan2123
« Reply #2 on: March 17, 2011, 09:36:55 am »
Prefer not to say  :happy2:
« Last Edit: March 17, 2011, 09:46:26 am by donovan2123 »
Offline vRS_Pagey
  • -Receive: 59
« Reply #3 on: March 17, 2011, 09:54:27 am »
Ah, a fellow briskodian if I'm not mistaken?
I have the Evoms intake and am more than happy with it, and as luck would have it,  there was one for sale on this very site. :happy2:
Offline edd666999
  • -Receive: 89
« Reply #4 on: March 17, 2011, 10:07:51 am »
Stage 1 is generally used on a standard car, the car shouldn't over fuel? Whats the logs like without the map (assuming you can take the map off)
Offline martziniuk
« Reply #5 on: March 17, 2011, 10:12:59 am »
Agreed stage 1 shouldn't require bolt on mods.
What figures are you getting regarding rich running at high RPM?
Offline donovan2123
« Reply #6 on: March 17, 2011, 10:37:57 am »
Hi dont have figures from the lamba log with me at moment as Im at work. But the timing pull is like -13 in some cases
Offline martziniuk
« Reply #7 on: March 17, 2011, 12:36:22 pm »
  :surprised: quite bad then!
Offline donovan2123
« Reply #8 on: March 17, 2011, 07:18:25 pm »
IS there anyo way i can upload log files?
Offline donovan2123
Offline donovan2123
« Reply #10 on: March 17, 2011, 07:22:33 pm »
Links to logs i took for my car. Can you guys kindly download and let me know what you think
Offline PDT
  • -Receive: 142
« Reply #11 on: March 17, 2011, 07:23:06 pm »
Just copy and paste a screenshot.
Running rich is unlikely to cause timing pull, running lean is worse. Was the AFR and ign pull datalogged or at least dyno tested when the map was installed? Any faults showing up?
This sounds very familiar to a car I tested recently with a stg1 map that was a diy install with a handheld device, wonder if its from the same tuner? (that car was an audi tt 200hp tfsi)
Offline martziniuk
« Reply #12 on: March 17, 2011, 07:31:24 pm »
Where are AFR logs?
Quite a lot of boost there.
Offline donovan2123
« Reply #13 on: March 17, 2011, 07:41:56 pm »
I have logged AFR. Which blocks are they ? Il do that over the weekend.
Offline donovan2123
« Reply #14 on: March 17, 2011, 07:44:04 pm »
One thing i will say is i was going through the service history and i have to say i cant see any information to say the air filter has ever been changed? I have not only the service book but reciepts for parts and labour non of which show air filter ever being changed.
