Author Topic: RNS 510 SAT NAV WILL NOT WORK WITH POST CODES  (Read 17294 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: RNS 510 SAT NAV WILL NOT WORK WITH POST CODES
« Reply #15 on: March 22, 2011, 01:14:17 pm »
If the car is under 2 years old and the nav is factory fit then no way should it have V1 maps.
Have you put 2760 firmware on yet?
Get yourself another 5 posts so you can read PM's and then I might be able to help you out :wink:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #16 on: March 22, 2011, 02:25:29 pm »
At some point there would have been a V1 of the maps for the RNS510 and I guess its plausible it didnt have postcode database support.  Either way the dealer seem to be a bit clueless you might be better sourcing your own newer map version update your firmware and you will find the RNS510 a much easier piece of kit to deal with, big speed improvements and much better functionality.
Offline alexperkins
  • -Receive: 99
« Reply #17 on: March 22, 2011, 02:27:23 pm »
There should always have been post code support. Even my old MFD2 had 4 digit post codes!
Offline Roxy99
« Reply #18 on: March 22, 2011, 07:57:04 pm »
I would be more than happy with the older V6 Maps. I can live with a four digit postcode function
Any suggetsions on where I could get a disk - Can they be downloaded?
Dave
Offline alexperkins
  • -Receive: 99
« Reply #19 on: March 22, 2011, 08:33:56 pm »
They can be, but there is probably someone on here that can help you out with a copy of the disc as once its copied to the HDD, you dont need it anymore!
