Author Topic: Spanner...  (Read 14390 times)
Re: Spanner...
« Reply #15 on: March 02, 2009, 09:17:37 am »
Jay did you use the trolley jack to insert it properly.  :innocent:
Re: Spanner...
« Reply #16 on: March 02, 2009, 09:22:30 am »
yep, ive had the car up now, with the inserts in place. the front is on axle stands. the hole i used is just a bit set back from that one in the photo. its beneath the more rectangular panel with 2x t20 bolts!
Re: Spanner...
« Reply #17 on: March 02, 2009, 09:25:26 am »
I reckon Micsta's teeth will come out easier than those babies. i reckon warming them up is going to be your best option.  :smiley:
Re: Spanner...
« Reply #18 on: March 02, 2009, 09:41:55 am »
http://www.mk5golfgti.co.uk/forum/index.php?topic=684.0
This thread Jay links to others that may help.
Re: Spanner...
« Reply #19 on: March 02, 2009, 09:59:15 am »
i might just put the panel back on over the plug and buy two new ones! i dont wanna risk damaging it pulling it out, and not going back right into the correct hole
Re: Spanner...
« Reply #20 on: March 02, 2009, 10:24:50 am »
You could get a little jig saw blade and cut it out from the middle should be fine.  :smiley:
Re: Spanner...
« Reply #21 on: March 02, 2009, 10:32:00 am »
i was thinking a blow torch myself to melt it out! ;)
Offline Makaveli
Re: Spanner...
« Reply #22 on: March 05, 2009, 12:05:48 pm »
Thats the one! Thanks, I probably described it completly wrong! Any idea if you can pick these up off ebay or from VW direct?
Go to your VW dealer and ask for part no 7L0 012 233. It should be the wheel assist for the Touareg and shouldn't cost much over £4 iirc.
Just called VW, can you check that part number for me again, I think its 7L0 012 223 rather than 233 at the end?
Offline tony_danza
  • -Receive: 112
Sideways yo!
Re: Spanner...
« Reply #24 on: March 05, 2009, 12:19:43 pm »
Nice one! :happy2:
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
No more damage - Jack Pads from Audi S3 fit the GTI
« Reply #25 on: December 22, 2010, 11:58:49 am »
If You don't like damaged underbody parts any more from jacking your car at  :wink:
your local 'stealer' have a look at this:
S3 und TT got rubber inserts with plastic pieces plugging in in them.
Thes do fit all Golf Mk.V and Mk.VI and should fit all models on PQ35 platform.
Self explaining installation in about 15 minutes.
front:
rear:
Required parts:
part number ''german'' (number needed)
8N0 804 583 Gummipuffer/rubber inserts (4 x)
8P0 802 845 Aufnahme vorn links/plastic piece that plugs into rubber, front left (1 x)
8P0 802 846 Aufnahme vorn rechts/front right (1 x)
8P0 802 847 Aufnahme hinten links und rechts/rear left & right (2 x)
- can of wax e.g. VW: D 308 SP5 A1
- some kind of silicon lube spray
Should fit Golf V, Golf VI, Scirocco, A3, Touran, Passat, Touran, Octavia, Leon, Altea
and Toledo. Price in Germany for all parts: 43,32 € inkl. 19 % VAT + wax + silicon.
A true must have !!
"You get what you pay for."
Offline Norbreck21a
Re: Spanner...
« Reply #26 on: December 22, 2010, 01:04:54 pm »
In your part numbers above, are they the ones for the lower set of photos i.e. the front mounts complete with the undershield blanking piece, or the upper photo i.e just the rubber plug where you have to remove the under sheild cover ?
Also, would these be available from VW or only from Audi Dealers ?
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
Re: Spanner...
« Reply #27 on: December 22, 2010, 01:27:19 pm »
complete with the undershield blanking piece, ....
Yes !! Complete as shown on the pics I posted except the yellow stickers, that are homemade.
That doesn't matter. All VW- and Audi-garages should sell these items, maybe even Skoda.
The only difficulty when fittig ist to extract the old plastic pieces on the front.
I needed my complete 85 kg . . .  :wink:
Re: Spanner...
« Reply #28 on: December 22, 2010, 01:32:27 pm »
I think you will find that VW, Skoda and Seat can't look those parts up because they are locked out from doing so.
I asked my parts man at VW about them and he couldn't even view them for this reason.  :confused:
Just go to an Audi dealer or somewhere like TPS..  :happy2:
Offline damoegan
Re: Spanner...
« Reply #29 on: December 22, 2010, 03:25:06 pm »
Are you talking about the VW equavelent of this, http://www.awesome-gti.co.uk/product.php?xProd=3415&xSec=931 ?
I've made a few of these over the years  :happy2:
