Author Topic: Understeer is the enemy..  (Read 9433 times)
Offline Redev
« on: March 19, 2011, 09:27:09 pm »
Ok so I've had the Golf for about a month now and substituted the Bridgestones for some pilot sport 3's but find that the car still understeers, quite a bit. I'm fact.
My old TT was fitted with R32 arbs which transformed the car-are there any such revalations for the GTI?
Black GTI, DSG, Cruise control, MFD2,  Leather, MFSW with paddles, Parrot kit, Xenons, CD Changer, Armrest, Come home lighting/puddle lights, mod list in glovebox waiting for some cash and sunny weather....
Nasir
Re: Understeer is the enemy..
« Reply #1 on: March 19, 2011, 09:28:58 pm »
Check the tyre pressures, they can make a big difference. Also it would depend what you class as unacceptable understeer, every car will understeer at some point.
  • -Receive: 291
« Reply #2 on: March 19, 2011, 09:40:07 pm »
You can get ARBs for the car which should dial out some of the understeer.
Offline Redev
« Reply #3 on: March 19, 2011, 09:41:36 pm »
I'm running 36 front and 32 rear...I'm not expecting it to perform like the quattro but I def want to make it a little more confidence inspiring...
Offline Redev
« Reply #4 on: March 19, 2011, 09:42:57 pm »
Thanks Stealthwolf, any reccomendations on the ARB,s?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=fe151lj2uui51ctd5cv426apuq&/topic,19740.0.html
« Reply #5 on: March 19, 2011, 09:48:17 pm »
Eibach or autotech are the names that always pop up with regards to ARBs
Offline Redev
« Reply #6 on: March 19, 2011, 09:52:46 pm »
I'll look into the Eibachs..has anyone tried the ARBs from an R32? Just out of curiosity...
Offline Truckie
    • Formula Hot Laps
« Reply #7 on: March 19, 2011, 10:14:24 pm »
Are we talking road or track? Wet or dry?
Offline Janner_Sy
  • -Receive: 113
« Reply #8 on: March 19, 2011, 10:17:44 pm »
what tyres, were you hard on the power...
rear ARB, WALK and TT lower arms will kerb understeer without changing the ride comfort at all.  Or you could fit uprated suspension
« Reply #9 on: March 19, 2011, 10:28:21 pm »
Assuming you have a gti, I suspect you should first raise your rear tyre pressure to the recommended 35psi
Offline Truckie
    • Formula Hot Laps
« Reply #10 on: March 19, 2011, 10:50:05 pm »
 :scared:
Offline mortygttdi
  • -Receive: 146
« Reply #11 on: March 19, 2011, 10:59:00 pm »
The R32 ARB's are the same has the GTI and Audi S3, 22mm the golf 2.0 GT tdi uses a 24mm ARB at the front.
Darren
Offline sportyy
« Reply #12 on: March 19, 2011, 11:14:27 pm »
well, thats the best option to go in war with your enemy :laugh:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #13 on: March 20, 2011, 12:15:48 am »
''Understeer'' is a common question.
You'll find many suggestions in this forum (if you may look to).
I'd recommend this:
- high quality coilover like Bilstein B14 or KW V3
- Whiteline ALK for more caster and better traction
- TT arms for more camber
- anti roll bars (to avoid understeer: same diameter front + rear)
- best tyres you can get (e.g. Michelin PSS or Pirelli P Zero)
- same tyre pressure front + rear
Are you sure?
Some examples:
model / diameter front ( x thickness) / diameter rear (x thickness)
OEM:
A3 Ambition/S-Line: 22,5 x 3,5 / 20,7 x 2,8 both tube
Golf V GTI: 23,6 x 3,5 / 21,7 x 3,0 both tube
Golf V R32: 22,0 solid / 21,7 x 3,0 tube (4-motion)
Golf VI GTI: 23,6 x 3,5 / 21,7 x 3,0 PR-0BF or 21,7 x 3,6 PR-0BM (DCC?) both tube
Golf VI R: 22,0 solid / 21,7 x 3,6 tube (4-motion)
Scirocco R: 23,6 x 3,5 / 21,7 x 3,6 both tube
Touran 170 HP: 23,0 solid / 21,7 x 3,0 tube
Passat R36: 23,6 solid / 21,7 x 3,6 tube (4-motion)
Sharan 2011: 24.0 mm / 20.0 mm both solid
adjustable sport ARBs:
H&R 'regular': 26 / 22 mm both solid
Eibach AntiRoll: 26 / 23 mm both solid
KW clubsport: 26 / 23 mm both solid
H&R 'big boy': 28 / 24 mm  both solid
 (heard that there is a 28 mm rear as well on special order)
H&R 4-motion: 25 / 25 mm both solid
Whiteline: 24 / 24 mm  both solid
Neuspeed: 25 / 25 mm  both solid
APR/Hotchkis: 27 / 27 mm tube
(does anybody know thicknesses?)
KW CS are identical to Eibach, just painted yellow instead of dark red.
 :wink:
« Last Edit: March 20, 2011, 12:18:02 am by the bruce »
"You get what you pay for."
Offline TT-Turbo
« Reply #14 on: March 20, 2011, 12:41:55 am »
I think the idea of putting stiffer front roll bars on the front relative to the rear will still give understeer. Wouldn't it be better to go with a more neutral set up like Neuspeed or autotech has gone for? I love Eibach gear but find the ratio of stiffness in roll bars to not help with a understeering car.
