Author Topic: Will these MK6 OEM LED number plate lights work?  (Read 10352 times)
Offline david25
  • -Given: 19
« on: March 20, 2011, 01:29:55 pm »
Hi everyone, does anyone know if these MK6 OEM number plate lights will work with a MK5 (physical fit and be free of light out errors)?
These seem to work on the Scirocco and on the MK4, see http://uk-mkivs.net/forums/p/411061/2814209.aspx
« Last Edit: March 20, 2011, 03:14:50 pm by david25 »
Offline golfman
  • -Given: 17
Re: Will these MK6 OEM number plate lights work?
« Reply #1 on: March 20, 2011, 01:52:57 pm »
I have these on mine and they work great(cheers darren)
you can also change the bulb to a canbus error free LED bulb :happy2:
just make sure you dont buy the LED version as there will be errors on your clocks!!!
scott
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline TagnuT
« Reply #2 on: March 20, 2011, 02:00:37 pm »
scott
Aren't they canbus error free in the first place? If they aren't what's the real point in doing it?
Bye Bye Edition 30.
Offline golfman
  • -Given: 17
« Reply #3 on: March 20, 2011, 02:11:42 pm »
Yes they are canbus error free(brand new) but when you put in an LED bulb that will throw an error so you have to buy a canbus error free LED bulb if you are taking that route!!
scott
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: March 20, 2011, 02:59:44 pm »
^^^^ You need the standard MK6 ones to be able to add an error free W5W LED bulbs, these have a integrated LED's that require coding that's only available on the later Mk6 BCM/CEM  :happy2:
Offline david25
  • -Given: 19
Re: Will these MK6 OEM LED number plate lights work?
« Reply #5 on: March 20, 2011, 03:14:34 pm »
Damn, I was hoping it would be a simple PIN swap (like the MK4) but I guess the MK4 doesnt have bulb warnings in the BCM etc?
Offline TagnuT
« Reply #6 on: March 20, 2011, 04:57:43 pm »
Thanks for clearing that up  :happy2:
Bye Bye Edition 30.
Offline Gtiain
« Reply #7 on: March 24, 2011, 12:55:32 pm »
Hi mate, do you have a part number for these or a link to where I can get some? Cheers
Offline davo01
« Reply #8 on: March 24, 2011, 04:57:10 pm »
So do these come with bulbs!?
If so which type!?
Offline golfman
  • -Given: 17
« Reply #9 on: March 24, 2011, 05:07:47 pm »
Hi iain
this is the part number you need-1K8 943 021
cheers
scott :happy2:
Offline Gtiain
« Reply #10 on: March 24, 2011, 06:43:17 pm »
Thanks golfman  :happy2:
How much off the top of your head?
Offline david25
  • -Given: 19
« Reply #11 on: March 24, 2011, 07:24:51 pm »
If so which type!?
Yes the LED bulbs are built in, see the other pic on http://uk-mkivs.net/forums/p/411061/2814209.aspx
Offline winrya
« Reply #12 on: March 24, 2011, 08:28:06 pm »
Am I being stupid but what's the point in this mod? I just use led bulbs in mine which look identical and cost less than £10 and are error free.
Offline Betty02
    • iBett
« Reply #13 on: March 24, 2011, 10:37:37 pm »
Loads of people are saying these do give and error and to turn of the cold lamp temp (VCDS) or something? Is this dangerous?
ADMIN NOTICE: Please do not use the site for advertising!
Offline Betty02
    • iBett
« Reply #14 on: March 24, 2011, 10:47:16 pm »
Found some information, the once I have pictured above are the LED version and supposdily do not give an error, the part number for these is slightly diffrent.
1K8 943 021B
