Author Topic: Fitting RNS 510  (Read 5789 times)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Fitting RNS 510
« Reply #15 on: March 21, 2011, 10:26:37 am »
 :ashamed: New to this forum larky. Thanks again for your help lads
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Fitting RNS 510
« Reply #16 on: March 21, 2011, 01:49:52 pm »
I changed a Gateway yesterday for Pipston, wasn't too bad to do and thankfully all worked well.
You need to have a good idea of your previous coding when generating the new code for the replacement Gateway.
If you copy the code, and make a note of the label file used from the old one you can manually open LCode found in the RossTech folder, paste in the code and open the correct label file to tell you the options ticked.
With the new one fitted open the coding section and use the other open instance of LCode to cross reference.
Stu...
Offline Creatz
  • The Noob
Re: Fitting RNS 510
« Reply #17 on: March 21, 2011, 02:47:30 pm »
put it in this location
thats where i put mine and i get 8/10 Gps sats
Offline alexperkins
  • -Receive: 99
Re: Fitting RNS 510
« Reply #18 on: March 21, 2011, 02:48:23 pm »
You can actually put it higher if you put it through the top vent insert and pop it to the right so it sits just under the grille on top :)
Offline Creatz
  • The Noob
Re: Fitting RNS 510
« Reply #19 on: March 21, 2011, 02:50:20 pm »
i put mine there because it was magnetic, if the off chance it came loose then i would have to re-seal it on the plastic side :happy2:
Offline alexperkins
  • -Receive: 99
Re: Fitting RNS 510
« Reply #20 on: March 21, 2011, 02:50:51 pm »
Ah. The one I fitted the other day was self adhesive  :signLOL:
Offline Creatz
  • The Noob
Re: Fitting RNS 510
« Reply #21 on: March 21, 2011, 02:52:58 pm »
ahh.....
Top tip then.....
If its adhesive put it above the vent section,if you have the magnetic one place it like the pic  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Fitting RNS 510
« Reply #22 on: March 21, 2011, 03:29:54 pm »
Thanks for the pics :happy2: you're a helpful bunch
Offline Lyons
  • -Given: 18
Re: Fitting RNS 510
« Reply #23 on: March 21, 2011, 03:39:54 pm »
My car is going in to the dealer for a spot of work next week and I was thinking of killing 2 birds with 1 stone and getting them to code the new gateway.
I havent much faith in the dealer for having done 1 before, so how big a job is it for them? Is it straight forward if it is new to them?
I know for installing a new Maxidot unit, it should just be a case of them following the instructions on the VAS programmer.
Offline alexperkins
  • -Receive: 99
Re: Fitting RNS 510
« Reply #24 on: March 21, 2011, 03:42:11 pm »
You would hope they would just duplicate the settings, but there is no guarantee they wont royally screw it up like most dealers seem to.
Offline Creatz
  • The Noob
Re: Fitting RNS 510
« Reply #25 on: March 21, 2011, 06:25:38 pm »
i know Morty on these forums is a pro when it comes to this stuff,
might be worth messaging him and seeing if he is close by and if he
could do it for you
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Fitting RNS 510
« Reply #26 on: March 21, 2011, 07:43:06 pm »
I'm sure they can do it.  Whether they want to, or whether they get it right is a different matter.
Stu...
