Author Topic: My RNS510  (Read 4732 times)
Offline Johnny_tro
My RNS510
« on: March 22, 2011, 04:46:02 pm »
have a parrott connected - is there any interface plug for it to connect to the RNS?
Link?
or how much would it be to get the actual bluetooth working on the unit itself? is it easy to do?
Offline alexperkins
  • -Receive: 99
Re: My RNS510
« Reply #1 on: March 22, 2011, 04:52:45 pm »
Parrot is easy enough to get working. What did you have it connected to before?
You have to change the MUTE wire on the connector that will have been fitted to get it working on the RNS generally as it moved from one connector block to the other as I had on mine last week.
Offline Johnny_tro
Re: My RNS510
« Reply #2 on: March 22, 2011, 05:06:55 pm »
the previous owner had soldered two wires to the back of the unit.......no connector on it...just got two wires. White/cream and red if I remember.
Offline alexperkins
  • -Receive: 99
Re: My RNS510
« Reply #3 on: March 22, 2011, 05:09:05 pm »
 :confused: where had they soldered them onto exactly?
Offline Johnny_tro
Re: My RNS510
« Reply #4 on: March 22, 2011, 05:27:12 pm »
This was how it was orginally done....
Offline alexperkins
  • -Receive: 99
Re: My RNS510
« Reply #5 on: March 22, 2011, 06:23:17 pm »
Good god is all I have to say about that
Youll need to get the Quadlock loom for the parrot as it snaps into that hole next to the blue multipin connector
There should be a third yellow wire connected from the parrot kit to the black 8 pin plug on the quadlock to - this also has to be moved to the new loom
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: My RNS510
« Reply #6 on: March 22, 2011, 06:35:40 pm »
Lol, I've seen that before it's horrendous.
I guess a 'professional' installer who doesn't now about or wish to use the plugs to fit the unit properly.
You can buy the plug and a repair wire to use with it which will sort you out.
Stu...
Offline Johnny_tro
Re: My RNS510
« Reply #7 on: March 22, 2011, 06:55:03 pm »
Quadlock loom << best place to get ones guys? whats a decent price for one?
Should I just stick with my parrott rather than try get the 'PHONE' working on the RNS?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: My RNS510
« Reply #8 on: March 22, 2011, 07:00:13 pm »
What Quadlock loom do you want?  What do you want on the other end?
The RNS510 doesn't have a phone it simply has support for a phone  :happy2:
Stu...
Offline alexperkins
  • -Receive: 99
Re: My RNS510
« Reply #9 on: March 22, 2011, 07:01:25 pm »
All you'd need is the 10 pin Green Housing with 3 repair wires for Tel R + Tel R - and Tel Mute
Then its just a case of crimping :)
« Last Edit: March 22, 2011, 07:03:08 pm by alexperkins »
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: My RNS510
« Reply #10 on: March 22, 2011, 07:04:01 pm »
12 Pin Green Flat Contact Housing (Plug) Radio/Telephone Connection - 3B7 035 447 B
Don't have the wire number to hand at the moment but I'm sure someone will have.
Stu...
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: My RNS510
« Reply #11 on: March 22, 2011, 07:20:33 pm »
never mind buying the plug
I can't even see the pins on the unit :stupid:
Cluster and Key coding
Location Great Yarmouth
Offline alexperkins
  • -Receive: 99
Re: My RNS510
« Reply #12 on: March 22, 2011, 07:37:42 pm »
That photo was of the RCD310 eddie  :signLOL:
Offline Johnny_tro
Re: My RNS510
« Reply #13 on: March 22, 2011, 08:08:41 pm »
so I get one of these 3B7 035 447 B  < and simply attach the wires from the Parrot?
Is it expensive to get the phone option working on the RNS? and is it easy to setup?
« Last Edit: March 22, 2011, 08:10:21 pm by Johnny_tro »
Offline alexperkins
  • -Receive: 99
Re: My RNS510
« Reply #14 on: March 22, 2011, 08:10:01 pm »
Youll need some repair wires too..hold on ill get the part number
