Author Topic: My RNS510  (Read 4684 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: My RNS510
« Reply #15 on: March 22, 2011, 08:20:35 pm »
The repair wire that Alex will give you the number for will have 2 ends on each so you need two wires to get the 3 ends you need.
Buy the plug for a couple of ££ and then fix the wires onto your Parrot wires, fit them into the plug and away you go.
Stu...
Offline Johnny_tro
Re: My RNS510
« Reply #16 on: March 22, 2011, 08:21:42 pm »
 :happy2: :happy2: :happy2: I await
Offline alexperkins
  • -Receive: 99
Re: My RNS510
« Reply #17 on: March 22, 2011, 08:28:51 pm »
As stu says, buy 2 of this part number
000 979 009
Connect the wiring to these pins, and make sure you wire the Parrot wires appropriately - there will be three from the Parrot
Pin 6 –  Telephone audio input signal right, negative - Connect this to the WHITE wire
Pin 10 –  Telephone mute (mute switch for radio) - Connect this to the YELLOW wire **
Pin 12 –  Telephone audio input signal right, positive - Connect this to the RED wire
Crimp or solder them together, then pop each wire into its location in the housing. Youll need to pop the housing out its holder by sliding it out - its easy when you see it.
** The MUTE wire may not be connected to the radio at present - follow the loom that comes from the parrot to identify the mute wire. Its normally yellow on parrot kits, and connect this as above.
On the RNS510, if you dont connect the mute, it wont work  :signLOL: so make sure you connect it!
« Last Edit: March 22, 2011, 08:30:40 pm by alexperkins »
Offline Johnny_tro
Re: My RNS510
« Reply #18 on: March 22, 2011, 08:37:09 pm »
Great help all thank you soooooooooooo much!!! really.
Wish me luck lol I'll need it.
If it's as simple as the above should be a doddle.
Thank you again!!!
Offline alexperkins
  • -Receive: 99
Re: My RNS510
« Reply #19 on: March 22, 2011, 08:38:03 pm »
Hit the 'Thank You' button...you know you want to  :signLOL:
Aye it really is that simple - if you get stuck, just ask  :happy2:
Offline Johnny_tro
Re: My RNS510
« Reply #20 on: March 22, 2011, 08:38:50 pm »
where you from alex?
Button presssed  :happy2:
Offline alexperkins
  • -Receive: 99
Re: My RNS510
« Reply #21 on: March 22, 2011, 08:39:48 pm »
Down south in Poole - what about you?
Offline Johnny_tro
Re: My RNS510
« Reply #22 on: March 22, 2011, 08:52:35 pm »
West midlands chap.
SteveP is hopfully helping me re-code etc. I have room full of stuff but noooo one to help me fit it. lol I'm uselesssss
