Author Topic: ITG gone all Darth on me.  (Read 1362 times)
« on: March 22, 2011, 10:03:42 pm »
Since doing a recent track day my ITG magonex has gotten considerably louder. Before it used to just rumble a bit now it sounds like a pipe is off. there is no loss of performance just a constant sucking now.
Is this a possible fault somewhere or a characteristic.  :happy2:
Re: ITG gone all Darth on me.
« Reply #1 on: March 22, 2011, 10:12:34 pm »
Is the filter secure TC?
« Reply #2 on: March 22, 2011, 10:19:56 pm »
It should be, but i will check at the weekend, as mentioned it is performing ok.  :happy2:
« Reply #3 on: March 22, 2011, 10:25:08 pm »
Take it all off and reassemble it and check all the pipes
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=0s70688b3o32fb4nvb1fitch7m&/topic,19740.0.html
« Reply #4 on: March 22, 2011, 10:31:02 pm »
If its too loud for you, at a push I might be up for doing a swap for my stock intake!  :signLOL:
Offline jmspear
« Reply #5 on: March 23, 2011, 05:01:34 pm »
TC how is the idle? especially at start and when you come to a rest after a good run? on mine (with ITG) the vacumn pipe came off the brake assit unit, changed the noise (you could hear air being sucked in) the give away was the idle change though as it was leaking air into the inlet bypassing the ITG, other thoughts are knackered DV which is dumping air into the intake in a different way, when my PCV valve went oil built up in my DV and this changed the sound, just a few thoughts..........
Offline edd666999
  • -Receive: 89
« Reply #6 on: March 23, 2011, 05:13:59 pm »
mine is very loud, its louder than someone just talking in the car...
