Author Topic: HOW TO :- Edition 30 DV  (Read 23512 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=lk56a7ao0ff2b3rh96hfbrr8c7&/topic,19740.0.html
« on: March 23, 2011, 02:32:57 pm »
I know this is easy and takes 10mins, but unless youve done these things once they can be a bit daunting
*I take no responsibility*
TOOLS
Torx 20 Screwdriver
Torx 30 Screwdriver
HOW TO
Start by removing the air intake fixing bolts (torx 20)... one each side.
Push it toward the back of the engine bay and swing it to the right.
Remove the bolt (Torx 30) marked by the red arrow, this bolt attaches the DV to the engine block.
Removal of the bolt allows you to move the DV toward the front of the engine bay so you can access the other 3 torx 30 bolts.
Now is a good time to remove the electrical connector from the DV, just push the tab down and pull it off.
Starting with the bolt on the right (as shown below) remove the three bolts one by one in a clockwise direction.
(NB... ignore inconsistance in the photos... your clip will be unclipped  :P )
Once you have removed all Torx 30 bolts the DV will simply lift straight out.
Inspect the orange diaphragm for tears and either refit, or purchase the revision D DV which is part number 06H 145 710 D revision G is now considered the best OEM version
To replace simply reverse the above. Make sure that the DV is seated correctly when you replace the bolts, and take care not to thread the bolt which attaches the DV to the engine mounting bracket
Rich
« Last Edit: April 11, 2013, 07:57:52 pm by richwig83 »
Offline Resonance
  • ED 30 Steel Grey DSG
Re: HOW TO :- Edition 30 DV
« Reply #1 on: March 23, 2011, 04:09:08 pm »
 :congrats: :pomppomp:
I wondered how long it would take you to do the write up  :wink:
Well done, will be trying this at the weekend!
Richard
« Reply #2 on: March 23, 2011, 04:17:56 pm »
 :signLOL:
No probs!
« Reply #3 on: March 23, 2011, 04:29:32 pm »
I can't see the pictures Rich and Flickr says the albums private.  :sad1:
Offline Resonance
« Reply #4 on: March 23, 2011, 04:31:21 pm »
Thats odd! I can see all the photos on his thread  :confused:
« Reply #5 on: March 23, 2011, 04:49:19 pm »
*Fixed photos*
(I made them private on flickr so they disappeared here)
Offline SteveS
« Reply #6 on: March 23, 2011, 04:55:47 pm »
Told you it was easy.. :)
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
« Reply #7 on: March 23, 2011, 04:57:00 pm »
Dead easy... but I like "how to" guides!  :signLOL:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #8 on: March 23, 2011, 05:12:20 pm »
Thanks i need a guide like this as my diy skills are horrendous.
out of interest does the revision d DV offer anything over the original in terms of performance or is it merely a more sturdy design?
« Reply #9 on: March 23, 2011, 05:16:10 pm »
From what i can gather its just a more robust design. The diaphragm revision is more prone to failure if you are remapped.
Offline alexperkins
  • -Receive: 99
« Reply #10 on: March 24, 2011, 07:29:23 am »
Having swapped mine to a Rev D it boosts much harder than before, even with my Rev C in perfect condition  :signLOL:
Offline baldwined30
« Reply #11 on: March 28, 2011, 08:13:29 pm »
Think this is my next upgrade! great write up!!!
Ed30
Offline Rampage
« Reply #12 on: May 10, 2011, 07:33:05 pm »
Fantastic guide buddy. All printed off and ready to check/replace my dv on my ED30. Quick question... do you use a bit of thread lock when putting back on? Can't remember if I've read you do somewhere before?
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #13 on: May 10, 2011, 10:38:31 pm »
Top write up! Will be trying this! Is there an age when the rev D was used or will all mk5's have the rubber diaphragm?
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline chris s
« Reply #14 on: May 16, 2011, 09:11:37 pm »
Great guide... very easy to do... only took me about 30 mins max!
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
