Author Topic: Aircon fuse?  (Read 7457 times)
Offline SteveS
Aircon fuse?
« on: March 25, 2011, 03:52:38 pm »
When the light is on its in ECON mode = no aircon. then light off aircon should be on, however the engine revs don't change, fans all sound the same.. doesn't feel like its turning on?
Is there a fuse i should check, couldn't find one in the handbook..?
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline barratt
Re: Aircon fuse?
« Reply #1 on: March 26, 2011, 05:39:12 pm »
Take a look at http://www.golfmk5.com/forums/attachment.php?attachmentid=17483&d=1193700739
From what I can at deduct, the fuse panel you want is on the drivers side. It seems to be either fuse 14 or 12, not making much sense of it really. Pull both out to see if they're gone?
There is a couple of different fuses related to the heaters and switches but It wont harm to check them all.
MK5 1.9 TDI BXE - AET Turbo's Remap - 140hp/325nm - GTTDI Leathers - GTI Headlights - R32 Rear lights - HEX+CAN VCDS
Offline DaveR77
    • UK-MKIVS.net
Re: Aircon fuse?
« Reply #2 on: August 09, 2011, 10:04:46 pm »
Did you find out which fuse it was?
