Author Topic: Weirdest Connections I've EVER seen....HELP  (Read 7984 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Weirdest Connections I've EVER seen....HELP
« Reply #15 on: March 25, 2011, 08:42:29 pm »
MDI should work with your RCD according to this - http://www.my-gti.com/688
But you only have a very small part of it.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #16 on: March 25, 2011, 08:43:01 pm »
That's alot missing  :grin:
Can I just have the ipod in the glovebox rather than armrest?
Yes, just needs a slightly different part number.
Stu...
Offline johnhol78
« Reply #17 on: March 25, 2011, 08:45:04 pm »
Yes the one with the Blue and Sand coloured plugs is the original.
MDI connection depends on what kit you bought but generally power, CAN and sound.
So the original is connected in the picture and the loose one is the parrot one?
Sorry just re read and saw that the one connected to the radio in the pic is the original OEM one.
just need to remove the other one?
« Last Edit: March 25, 2011, 08:47:38 pm by johnhol78 »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #18 on: March 25, 2011, 08:47:06 pm »
Yes that's what it looks like from your pictures.
However there is another retrofit which may well be an MDI.  I sort of recognise the adaptor.  The wiring loom that has the brown cable on it, trace that back and see if there is an interface on the end of it.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #19 on: March 25, 2011, 08:48:55 pm »
Looking at the pictures I am starting to think there is an MDI already in there.  Did the previous owner give you the small iPod lead?
Stu...
Offline johnhol78
« Reply #20 on: March 25, 2011, 08:49:53 pm »
Brown one seems to just loop back on itself.....will strip the lot out tomorrow and have a second butchers.....
Would removing the glovebox make it easier to remove the retrofit one.....did on my BMW.
Offline johnhol78
« Reply #21 on: March 25, 2011, 08:50:49 pm »
Nope just a connection in the glovebox for an iPod.....this feeds into a connector block called an iPod Connector...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #22 on: March 25, 2011, 08:55:44 pm »
The situation with the brown wire is, the original brown has been removed from the large (quadlock) connector and the smaller single connector fitted.  The brown from the retrofit wiring loom is spliced inside the loom to link the flying lead and another which the goes into the quadlock plug in place of the brown that was removed.  That I believe will be connected to the media device.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #23 on: March 25, 2011, 08:58:35 pm »
That's an old school iPod adaptor the same as this one on my website -
http://octavia-vrs.com/cms/content/ipod-adapter
and explains the brown wire that I was trying to explain above.
Stu...
Offline johnhol78
« Reply #24 on: March 25, 2011, 08:59:15 pm »
Going to have to look tomorrow......but the iPod connector one side goes to my iPod and the other connects into the back of the stereo.........
Will have a root around and see if the MDI is there...
Wish I never started now.....or was given this cable...thought it would a case of plug in and boom........serves me right for thinking it would be simple...
Thanks for the help Stu....will post more pics etc tomorrow if you're about....
Think I owe you a beer...
Offline mb
  • -Receive: 29
« Reply #25 on: March 25, 2011, 09:00:01 pm »
I removed that iPod adapter from my car last week & fitted the MDI. I'm not doing a lot tomorrow so can pop over if you need a hand
Offline johnhol78
« Reply #26 on: March 25, 2011, 09:01:36 pm »
If you could that would be great.....do I need to buy anything else for this to work or would the cable I got (same as eBay) work with existing setup?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Stu...
Offline mb
  • -Receive: 29
« Reply #28 on: March 25, 2011, 09:05:33 pm »
You'll need the rest of the MDI kit as the lead you have just connects the iPod to the flying lead of the control box.
I've still got your number so will be in touch tomorrow
