Author Topic: Weirdest Connections I've EVER seen....HELP  (Read 7965 times)
Offline johnhol78
Re: Weirdest Connections I've EVER seen....HELP
« Reply #30 on: March 25, 2011, 09:10:19 pm »
If you could that would be great.....do I need to buy anything else for this to work or would the cable I got (same as eBay) work with existing setup?
You'll need the rest of the MDI kit as the lead you have just connects the iPod to the flying lead of the control box.
I've still got your number so will be in touch tomorrow
How much is the extra part? Do you know the part number or where I can get one....if it's expensive then I'll have to make do with the current setup...wifes car cost me £600 yesterday  :surprised:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #32 on: March 25, 2011, 09:12:54 pm »
Main dealer retail price for that part is £137 +VAT
Stu...
Offline johnhol78
« Reply #33 on: March 25, 2011, 09:13:53 pm »
Definitely have to wait....but if you know how to swap the pins so it stops buzzing would be valuable for now.
Offline mb
  • -Receive: 29
« Reply #34 on: March 25, 2011, 09:22:50 pm »
Yeah I've done that on mine.
I'll be in touch tomorrow
Offline johnhol78
« Reply #35 on: March 26, 2011, 12:43:10 pm »
Massive thanks to Martin (mb)
Swapped the pins over on the iPod connector....then got the VAGCOM out and scanned and coded where needed......now THAT is how the soundpack should sound....what a difference.
 :drinking:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #36 on: March 26, 2011, 01:03:09 pm »
Glad it's all sorted.
Stu...
Offline johnhol78
« Reply #37 on: March 26, 2011, 01:05:32 pm »
Thanks for the help stu last night....
The HU was not coded for soundpack though we found the settings, changed them and WOW  :surprised:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #38 on: March 26, 2011, 01:10:00 pm »
It's often a problem with units bought from eBay etc which are sold as plug and play 'no coding required'.
Stu...
Offline mb
  • -Receive: 29
« Reply #39 on: March 26, 2011, 02:46:37 pm »
 :drinking:
It did sound good!
Offline johnhol78
« Reply #40 on: March 26, 2011, 05:52:54 pm »
Think it sounds better when the engines not running though.....almost louder and with more bass.\
Could the fact the wrong CAN gateways installed cause an issue when the engines running?
