Author Topic: Exhaust rubber bush has torn  (Read 1353 times)
Offline Rob GTI
« on: March 25, 2011, 08:36:22 pm »
Had my car up on the ramp today and noticed this:-
The car has a Milltek TBE and VWR lower rear mount (Fast road), anyone else had any issues of this bush breaking like so, also can this bush be bought on its own? Does it look as if it has been fitted correctly?
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Exhaust rubber bush has torn
« Reply #1 on: March 25, 2011, 08:45:38 pm »
I think you need the whole bracket.
Stu...
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« Reply #2 on: March 25, 2011, 08:49:42 pm »
This is known to happen with the Milltek. I have heard of this a few times but the replacement part is cheap.
Offline Rob GTI
« Reply #3 on: March 25, 2011, 10:03:03 pm »
I'm just looking at the close up pic (bottom) one again and it seems the metal underneath the bush is distorted possiblly where someone has used a screwdriver to lever the rubber on the hanger??
« Reply #4 on: March 25, 2011, 10:10:03 pm »
Do you have a torque mount insert installed?
iirc RedRobin had a similiar issue with his car and it occured because of engine movement.
Offline Rob GTI
« Reply #5 on: March 25, 2011, 10:42:12 pm »
I've got the VWR lower rear bush which is what RR replaced his insert for so should therefore be better. The VWR bush was fitted before the Milltek even!!
Offline pobmk4
« Reply #6 on: March 25, 2011, 11:33:16 pm »
Ive seen this happen with a couple of GTi's, both had millteks fitted - i think its actually a problem with the length of the mounting arms - they are slightly longer than a standard exhaust - but i'd have thought the uprated bushing would have helped due to the lack of movement!!
