Author Topic: TT or S3 fron suspension arms  (Read 22667 times)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: TT or S3 fron suspension arms
« Reply #45 on: November 18, 2014, 10:17:00 pm »
Your right they don't, but with the Superpro adjustable ball joints as suggested they do.
TT arms and ball joints give negative camber, but they also give an extra 10mm track which can cause problems with rubbing if you have aftermarket wheels or running low
That's why I suggested getting the Superpro, you get the weight saving of the alloy arms and the negative camber from the ball joints and save the hassle of rubbing  :wink:
I've run the TT arms previously and have moved to the set up above for the reasons stated
HTH.  :drinking:
Offline edd30
« Reply #46 on: November 18, 2014, 10:39:24 pm »
I see what you mean now - I'm unlikely to lower the car - too many pot holes around here. Don't suppose you are selling your TT arms ?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #47 on: November 19, 2014, 12:01:58 am »
There long gone at this stage  :happy2:
Offline sgour
« Reply #48 on: December 27, 2014, 10:12:18 pm »
Im a bit in over my head at this since Im not really mechanically minded, but if I were to get the TT or S3 suspension arms are they just a direct fit/replacement or do I require anything else? Ive a creaking coming from this area and I figure its the bushes so I might as well upgrade them if they are going to have to come off anyway.
I already have the superpro anti lift kit and ball joint kit.
Offline BlackMk5Gti
  • ~DSG LYFE~
« Reply #49 on: July 14, 2015, 06:34:45 pm »
HTH.  :drinking:
Sorry to resurrect an old thread but....I'm guessing all of you are playing with all these suspension components but don't have upgraded brakes?? I have 6 pot AP calipers and 356x32mm 2 piece AP discs. I purchased the superpro adjustable ball joints, went to fit them and they hit the back of my brake disc. Would fitting TT arms give me the -2.0 degrees of camber i am looking to achieve?
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #50 on: July 15, 2015, 08:44:21 am »
HTH.  :drinking:
Depending on the hubs you have, then yes. Actually the TT hubs will allow for the lowest amount of negative camber, on S3/Passat alloy hubs the TT arms has to be fitted opposite of how they are intended to be fitted with the TT hubs, which will allow for quite a large amount of negative camber. I have made a tread on here where the different options are explained
http://www.mk5golfgti.co.uk/forum/index.php/topic,41189.0.html
Over the top mod list ;o)
Offline vRSAlex
  • -Receive: 253
« Reply #51 on: July 21, 2015, 02:39:46 pm »
TT ball joints with probably foul the discs too. Better off with adjustable top mounts.
Follow AKS tuning on Facebook
