Author Topic: DIY Service  (Read 5094 times)
Offline johnhol78
DIY Service
« on: March 30, 2011, 03:13:01 pm »
Going to do my own service, Oil change, Oil Filter, Spark Plugs, Pollen filter and Air Filter (New Pipercross).
Using Castrol Edge and OEM parts elsewhere except the air filter so will be a better job than a garage.
Problem is the Service Indicator...
How is this reset - via Vagcom or is it via the trip comp (midline)?
Offline Betty02
    • iBett
Re: DIY Service
« Reply #1 on: March 30, 2011, 03:24:12 pm »
From past experience I think its -
Ignition Off
keys Out
Hold 0.0 Near Clocks
Key In
IGNITION ONLY ON
Press Minute Button near clocks
That should do you ;)
ADMIN NOTICE: Please do not use the site for advertising!
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: DIY Service
« Reply #2 on: March 30, 2011, 03:25:35 pm »
you can use VCDS to reset it but there is also a button combination that will reset the indicator.
Not tried it but this should do it
http://wiki.answers.com/Q/How_do_you_reset_the_service_reminder_on_a_2006_VW_Golf_GTI_Mk5
seen a post saying it also tells you how to in the manual.
Offline alexperkins
  • -Receive: 99
Re: DIY Service
« Reply #3 on: March 30, 2011, 03:27:16 pm »
VCDS is a better way to reset it, as you can use the SRI tool to get the setting perfect for how you want it setup rather than just defaults  :happy2:
Offline johnhol78
Re: DIY Service
« Reply #4 on: March 30, 2011, 03:28:45 pm »
What setup??? Do i need to bother or is this a 'nice to have'?
Someone nearby has VCDS so think he may help out  :wink: (mb)
Offline alexperkins
  • -Receive: 99
Re: DIY Service
« Reply #5 on: March 30, 2011, 03:32:27 pm »
You can fully customise the service timing and mileage if you want to
Its a nice to have lol! I wouldnt be too worried
Offline cata_adc
    • Adciel Bosch Car Service
Re: DIY Service
« Reply #6 on: March 30, 2011, 05:51:37 pm »
you can use vag-com or other programs such as bosch kts or others
Offline alexperkins
  • -Receive: 99
Re: DIY Service
« Reply #7 on: March 30, 2011, 06:24:12 pm »
VCDS is Vagcom mate. (Vag Com Diagnostic System)
Nasir
Re: DIY Service
« Reply #8 on: March 30, 2011, 06:47:24 pm »
AFAIK the button reset only works on the T&D right?
Offline alexperkins
  • -Receive: 99
Re: DIY Service
« Reply #9 on: March 30, 2011, 07:09:31 pm »
It works on Longlife, but will reset the car to T&D
If you are on longlife and want to stay on it, its either VCDS or a dealer to reset.
Offline johnhol78
Re: DIY Service
« Reply #10 on: March 30, 2011, 07:12:25 pm »
It's seems to be every 10k.....so is this longlife?
Offline alexperkins
  • -Receive: 99
Re: DIY Service
« Reply #11 on: March 30, 2011, 07:13:27 pm »
Longlife is 20k (ish)
TandD is every 10k
Offline johnhol78
Re: DIY Service
« Reply #12 on: March 30, 2011, 07:14:54 pm »
TandD is every 10k
Then it's T&D..... :happy2:
Offline mb
  • -Receive: 29
Re: DIY Service
« Reply #13 on: March 30, 2011, 08:12:53 pm »
I could do but I'm not sure how to do it
Offline johnhol78
Re: DIY Service
« Reply #14 on: March 30, 2011, 08:26:30 pm »
no worries mate, will try the button combo first...
