Author Topic: Edition 30 GTI developed new throaty sound over 40 mph  (Read 4151 times)
Offline RID
« on: March 31, 2011, 04:47:13 pm »
I have an Ediiton 30 GTI with 76,000 miles which has recently developed a throaty sound when I go over 40 mph.  Kwikfit checked the exhaust and that's fine - has anyone come across anything similar?
Thanks in advance
Offline alexperkins
  • -Receive: 99
Re: Edition 30 GTI developed new throaty sound over 40 mph
« Reply #1 on: March 31, 2011, 04:48:39 pm »
Can you pinpoint where the sound is coming from? ie exhaust or wheels?
Offline RID
« Reply #2 on: March 31, 2011, 04:52:21 pm »
It sounds like it's coming from under the car as opposed to the engine but not sure it's the wheels - Kwikfit couldn't see any holes in the exhaut when they jacked it up
Offline alexperkins
  • -Receive: 99
« Reply #3 on: March 31, 2011, 04:53:04 pm »
Could be a wheel bearing perhaps
If its speed related, it cant be too many things
Offline RID
« Reply #4 on: March 31, 2011, 04:57:04 pm »
Thanks Alex - is that expensive to fix on these cars?
Offline alexperkins
  • -Receive: 99
« Reply #5 on: March 31, 2011, 05:03:03 pm »
Not too bad. About £30 for the part then labour on top
Would be worth taking it to a decent VW specialist and get them to have a listen
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=b334fbn22atvbjomeq0hoj7sgn&/topic,19740.0.html
« Reply #6 on: March 31, 2011, 05:03:55 pm »
Is it at 40mph only? Or 40 and above?
Offline RID
« Reply #7 on: March 31, 2011, 05:07:24 pm »
About 40 mph and above
Saint Steve
« Reply #8 on: March 31, 2011, 05:37:36 pm »
What sort of miles has it done? does it feel down on power? feels abit flat?
Offline RID
« Reply #9 on: March 31, 2011, 06:30:57 pm »
76, 000 miles - seems to drive ok though
Saint Steve
« Reply #10 on: March 31, 2011, 07:20:25 pm »
Might be worth looking at your Diverter valve? as its done over 70+K miles
If your mpg seems to be getting worse, then might be worth having a look.
Did kwik fit just tap the outside of the exhaust and check for signs of leaks, or did they use a endiscope to check the condition of the baffles inside the Back box?
Offline Five Alive
« Reply #11 on: March 31, 2011, 07:49:23 pm »
yeah could be the baffles gone, my girlfriends little polo gti sounds well throaty but exhaust looks fine
Offline RID
« Reply #12 on: March 31, 2011, 08:23:11 pm »
I guess Kwikfit only  did a superficial check.  Thanks to everyone for the input - much appreciated
Offline PDT
  • -Receive: 142
« Reply #13 on: April 01, 2011, 11:43:34 pm »
That made me chuckle, a lot. Kwik fit can rarely use a tyre machine properly, endoscope to check the baffles? The most complex tool in the workshop is probably the handle to flush the toilet.
golfecho5
« Reply #14 on: April 02, 2011, 12:10:38 am »
Wouldn't trust quick-dick for anything other than a cheap MOT. Most exhausts develop a throatier sound as they get older as the packing in the exhaust gets older and more compressed with sh*t but if you've had a sudden change in sound then you need to get someone who really knows their stuff to look at both manifolds and the turbo plumbing to make sure there's not a leak.
A tiny hole somewhere in the induction can cause a pretty good roar under torque but will reduce when top end power introduces itself to the engine, I'd say worth getting a spray bottle of soapy water and spraying around the turbo/induction tracts and getting a friend to hit the pedal hard for a second to get the turbo spooling/gain boost and see if you get any blow out.
If you're not confident doing this and you need to be careful where you spray then get a specialist to look, I suspect your problem is induction not exhaust taking into account how you suddenly heard the noise.
Good luck but if in doubt get a real expert who cares to look not Qwick- Tang. Most of them don't know there arse from their elbow.
Disclaimer: I'm sure that this comment does not apply to all who work at KrapQwick and there will be the exception to the rule.
