Author Topic: Walk and sportlines fitted today...  (Read 2769 times)
Offline aidogti
Re: Walk and sportlines fitted today...
« Reply #15 on: March 31, 2011, 11:21:41 pm »
Yeah standard shocks... i take it its ok to run these springs on standard shocks?
golfecho5
« Reply #16 on: April 01, 2011, 10:44:36 pm »
Yes, no problems with standard dampers, they work really well for fast road. You might get some bounce at high speed as the damper would have been designed for a full length spring like a Pro Kit rather than a Sportline but the match is pretty good. I whacked them on a Pro Damper which is not far off the standard GTi damper - if you ask Eibach/Sachs.
I only changed my dampers as it was no extra labour cost on top of doing the springs, so did both at the same time - oh, and my damperssprings had done 100,000 miles, they get a bit saggy after that.
Offline PDT
  • -Receive: 142
« Reply #17 on: April 01, 2011, 11:37:13 pm »
Silicone based spray is kinder to the bush and lasts longer than wd40 :wink:
http://www.screwfix.com/p/3-in-1-oil-pro-silicone-spray-lubricant-400ml/52410
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #18 on: April 02, 2011, 12:37:39 pm »
Don't use WD40 for rubber !!!
Use silicon spray.  :wink:
"You get what you pay for."
