Author Topic: RCD310 Help required  (Read 1624 times)
Offline GLIDN
« on: April 01, 2011, 05:03:57 am »
Ok I installed a RCD310 into my 2005 Golf GTI finally.
The little issue I'm having is the following.
Sometimes the radio turns on and off correctly from the key. Other times I have to manually turn the radio on after car has been started, or turn the radio off after the key has been removed.
So do I need to make any changes in the CAN-BUS, to allow for the new radio?
or are the CAN-BUS cables swapped around in the mk6?
I have not yet checked which revision CAN-BUS Gateway I have. Otherwise I have to get new newer CAN-BUS I'm assuming.
Any help would be appreciated.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: RCD310 Help required
« Reply #1 on: April 01, 2011, 06:16:35 am »
Hi
you need a new Can Gateway or you will have a flat battery
Cluster and Key coding
Location Great Yarmouth
Offline GLIDN
« Reply #2 on: April 01, 2011, 06:45:46 am »
Hi
I know that one. Thanks for that.
I use the car everyday. So not too worried about that.
More worried about above mention issue.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: April 01, 2011, 06:04:40 pm »
changing to a newer gateway should solve your problem
Offline GLIDN
« Reply #4 on: April 01, 2011, 11:06:18 pm »
Ok, remembered what I had done. Duh
I had to run an aftermarket radio for the past 9 months. Got annoyed with the radio comm error everytime I scanned the car.
So I disabled the radio coding in the can-bus. That is why I was having this issue.
Thanks for your help.
