September 21, 2024, 03:59:02 pm
All Things Mk5
How to Guides / Troubleshooting
Dash light ?
Topic: Dash light ? (Read 1434 times)
stevw1
Always Involved
-Given: 5
-Receive: 12
Dash light ?
April 01, 2011, 09:39:55 pm »
Got a light on the dash, in the speedo, exclamation mark with a squiggle (if that makes sense)same as the SET button next to ESP on the ashtray front. I had a brake-light out when it came on,i have replaced the bulb but its still on ?
Steve
stealthwolf
Just look at my post count
-Given: 306
-Receive: 291
ED30 No.1412
Re: Dash light ?
Reply #1 on:
April 01, 2011, 09:47:20 pm »
Is it the tyre pressure warning light?
Have you checked your tyre pressures? Once they are at the correct pressure, press and hold the set button until you hear a bong. You may have a puncture.
The
GTI
isn't just a machine. It's very much a living, breathing thing.
stevw1
Always Involved
-Given: 5
-Receive: 12
Re: Dash light ?
Reply #2 on:
April 01, 2011, 11:30:43 pm »
WOW !
Ive been driving a MK4 for 6yrs, only had the MK5 a few days its taking some getting used to. It has so many tricks n toys in a good way though.
Thanks for the reply will be checking ASAP.
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Re: Dash light ?
Reply #3 on:
April 02, 2011, 07:57:20 am »
if all pressures are ok, press the (!) SET button till you hear a beep.
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
big al
-Given: 27
-Receive: 93
Re: Dash light ?
Reply #4 on:
April 02, 2011, 11:45:50 am »
Should say what it is in your service book mate.
I had one come on the other day and had to pull over to find out what it was, turned out it was just the indicator LEd broken.
stevw1
Always Involved
-Given: 5
-Receive: 12
Re: Dash light ?
Reply #5 on:
April 02, 2011, 03:53:31 pm »
All sorted now.
Cheers Guys
All Things Mk5
Dash light ?
