Author Topic: Rad fans coming on, 30s from start-up??  (Read 5402 times)
Offline alexperkins
  • -Receive: 99
Re: Rad fans coming on, 30s from start-up??
« Reply #15 on: April 03, 2011, 08:02:28 pm »
Leave it with me
Offline AnilS
  • -Given: 50
« Reply #16 on: April 14, 2011, 05:30:52 pm »
Hi Alex, any joy? :smiley:
Offline alexperkins
  • -Receive: 99
« Reply #17 on: April 14, 2011, 05:31:25 pm »
Update coming soon!
Offline QD MBE
  • -Receive: 102
« Reply #18 on: April 14, 2011, 08:19:42 pm »
The part number depends on the make of fan currently fitted, you can't mix and match.  Siemens and Temic are the two makes given in the parts cat.
Fan on AXX engine
1K0 959 455 ET -Siemens (200W/295mm Right).
1K0 959 455 CR -Temic.
1K0 959 455 Dt is 300W/360mm left Siemens
1K0 959 455 CQ is 300W/360mm left  Temic
1K0 121 207 BB 9B9 is the actual Cowl.
All the above is not cheap, comes to around £360, 60 for the shroud and 160/140 for the fans.
Offline alexperkins
  • -Receive: 99
« Reply #19 on: April 14, 2011, 08:45:07 pm »
Cheers QD I was just about to post a very similar one!
AMR_450
« Reply #20 on: April 20, 2011, 01:37:13 pm »
Hi all
First post but i have been a lurker for a long while
Thought i would share something from my SEAT days
On my LCR, i had exactly the same issue with the fan resistors burned and the fan running flat out
I used this mod to fix the issue without having to replace the fans
I know its a bit of a fiddle and involves some mechanical know how and cutting of wires but its a cheap fix
Not sure if it's applicable on a MK5 but any info is a help
http://uk-mkivs.net/forums/p/59897/449470.aspx#449470
« Last Edit: April 20, 2011, 01:38:53 pm by AMR_450 »
Offline AnilS
  • -Given: 50
« Reply #21 on: August 12, 2011, 07:56:58 pm »
Well I finally got round to sending the car to my Indy. After diagnostics showed a faulty temp sender, new one was ordered. The odl one was reading randomly and causing the fan to come as a precaution.
£130 (all in) later and so far so good. :happy2:
