Author Topic: Full fis clocks into a GT TDI  (Read 3956 times)
Offline stevw1
« on: April 03, 2011, 11:41:49 pm »
Can i get these to work in my GT TDI 140 05 plate?
IMG_6407 by stevw1, on Flickr
Any help is most appreciated  :wink:
Offline apollo13
  • -Receive: 47
Re: Full fis clocks into a GT TDI
« Reply #1 on: April 04, 2011, 05:18:45 pm »
Not sure if they are  diesel or petrol clocks as Im not up on that part of the part number but 974 clocks can only be done by a specialist, unless they come with the SKC code??
Look for clocks ending in 970 971 or 972 and I and a few others on here can fit and code them.
Offline stevw1
« Reply #2 on: April 04, 2011, 05:23:09 pm »
I have the SKC Code and an eprom readout. Also have access to VAG-COM. They are from a Jetta TDI Highline i believe.
Possible ?
Offline apollo13
  • -Receive: 47
« Reply #3 on: April 04, 2011, 05:24:47 pm »
If you have the SKC then yes.
The VAG COM way of coding clocks is a little long winded though IMO.
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_IV_Immobilizer_Swapping_(Instrument_Cluster)
Using VAG K+ CAN Commander to copy over the IMMO data is much easier and the only way I have done these swaps in the past.
« Last Edit: April 04, 2011, 05:32:50 pm by apollo13 »
Offline stevw1
« Reply #4 on: April 04, 2011, 05:32:09 pm »
Thats good, thanks for the info  :happy2:
At a later date i want to fit an mfsw from an R, will there be any issues ?
Offline apollo13
  • -Receive: 47
« Reply #5 on: April 04, 2011, 05:34:43 pm »
No issues at all.
You just need to make sure you have the correct slip ring, steering control module and airbag harness  :happy2:
Offline stevw1
« Reply #6 on: April 04, 2011, 05:43:28 pm »
HAPPY DAYS ....................
Wish you were nearer, sound like you know your stuff. You have a build thread? Interested in the headlights you have.
« Last Edit: April 04, 2011, 05:48:36 pm by stevw1 »
« Reply #7 on: April 04, 2011, 05:47:52 pm »
i have  a mk6 steering wheel that me and Darron swapped-he fitted it for me and i thing Eddie nl got the buttons working as well for his radio
Offline stevw1
« Reply #8 on: April 04, 2011, 06:20:45 pm »
Seems my VAG-COM guy is not au-fait with the MKV  :sad1:
Who is nearbye that can do it for me ?
Offline apollo13
  • -Receive: 47
« Reply #9 on: April 04, 2011, 08:22:55 pm »
Where are you mate?
As for my headlights, they dont make them anymore....only the halogen versions that don't turn or self level.
Mine use D2S bulbs like OEM Xenons.
« Last Edit: April 04, 2011, 08:25:13 pm by apollo13 »
Offline stevw1
« Reply #10 on: April 04, 2011, 08:39:38 pm »
Where are you mate?
Manchester M34
Bummer, bet they look cool  :smiley:
Offline apollo13
  • -Receive: 47
« Reply #11 on: April 04, 2011, 08:42:46 pm »
Yes they do  :grin:
I had a visit from someone in Devon for a MFSW and highline cluster swap........7hr round trip.
Offline daboy3000
  • MKV GT TDi
« Reply #12 on: April 08, 2011, 03:35:46 pm »
My midline screen fades when its warm, if I just buy a set of TDi clocks off ebay can I just swap them around without any issues? Is the mileage stored elsewhere or do I have to change it?
Offline apollo13
  • -Receive: 47
« Reply #13 on: April 08, 2011, 05:15:46 pm »
No, the same rules apply when you upgrade any clocks. Even if its like for like the immobiliser info still needs copying over to the new clocks................but if your only swapping a midline for another midline (or highline for highline) you could just swap the front of the clocks over as the back part of the clocks contains the immo/mileage data.
« Last Edit: April 08, 2011, 05:17:59 pm by apollo13 »
« Reply #14 on: April 08, 2011, 05:53:58 pm »
I have a midline set of clocks for sale that i took out of my 54 plate gttdi
