Author Topic: eBay bog brush  (Read 1747 times)
Offline Jack Rabbit
  • Born on Beat
eBay bog brush
« on: April 06, 2011, 07:58:14 pm »
Is there a recommendation for brushes for the alloys?
Nothing to harsh but not too soft, and long enough to reach the inner dish yet narrow to get between the spokes, where would I buy such an item?
I'm not a pro detailer so don't want to spend a weeks wages on it, but happy to spend the right amount on the right thing
What are people using and how do you rate it?
Many thanks  :smiley:
Offline QD MBE
  • -Receive: 102
Re: eBay bog brush
« Reply #1 on: April 06, 2011, 08:20:34 pm »
  • -Receive: 291
Re: eBay bog brush
« Reply #2 on: April 06, 2011, 10:16:25 pm »
^^^I have the full version of the same brush. I use a mild cleaner like bilberry wheel cleaner. Once cleaned, you can use a clay bar to make sure there are no contaminents and then seal with a wheel sealant. That way, you don't need to keep brushing them.
Offline Jack Rabbit
  • Born on Beat
Re: eBay bog brush
« Reply #3 on: April 06, 2011, 10:19:05 pm »
Wheel sealant - wax?
Offline Tarmac_Terrorist
Re: eBay bog brush
« Reply #4 on: April 06, 2011, 10:42:23 pm »
I have both the large and small EZ Detail brushes. Wouldn't be without them now and wear reasonably well.
I think Vikan also make some nifty brushes - try googling them.
  • -Receive: 291
Re: eBay bog brush
« Reply #5 on: April 06, 2011, 11:03:25 pm »
High temp sealant used for alloys. Can also be called wheel wax eg poorboy's wheel sealant. As I mentioned, if you apply it after cleaning the wheels, you won't have to keep using brushes and cleaners to clean them - just use a pressure washer .
Offline Kalpsn2000
  • -Receive: 56
Re: eBay bog brush
« Reply #6 on: April 12, 2011, 02:50:55 pm »
Chemical Guys Jet Seal 109 is supposed to be a decent wheel sealant :happy2:
Offline uk_stu
Re: eBay bog brush
« Reply #7 on: April 14, 2011, 04:40:29 pm »
