Author Topic: Drivers side mirror came off -EDIT NOW DOOR WON'T LOCK+ADJUSTER NOT WORKING!  (Read 8112 times)
Offline dajackel12
Hey guys, As the title says my driver's side mirror glass was loose for the last few days, I went to check it out and it came off from the backing, The backing (with the 2 wires) seems to be fine but it's just the glass bit that's got unstuck from it,
I am wondering what's the best way to get this sorted? Can I just stick it back on with some glue to the backing? If so will the heated function still work?
« Last Edit: April 08, 2011, 11:54:55 pm by dajackel12 »
  • -Receive: 291
Re: Drivers side mirror came off today! need advise!
« Reply #1 on: April 07, 2011, 07:01:55 pm »
The wires clip onto the mirror.
Can you push the mirror back onto the base? It may have just popped off, in which case it can be replaced.
Offline dajackel12
« Reply #2 on: April 07, 2011, 07:08:10 pm »
Hi
Thanks for the quick reply,
I can put the glass back onto the backing bit (where the wires are connected) but it doesn't stick to that, I will quickly take a picture and upload it.
Offline dajackel12
« Last Edit: April 07, 2011, 07:28:07 pm by dajackel12 »
Offline boxxer1973
« Reply #4 on: April 07, 2011, 07:51:33 pm »
i got a funny feeling you have your mirror demisters on ? same happened to me they don't turn off and melts the glue
Mk5 golf Gti REVO. stg2+
Milltek | Auto tech | White line | Forge | REVO | KW | Quaife | helix clutch |
Offline dajackel12
« Reply #5 on: April 07, 2011, 08:01:25 pm »
Hi mate
The light's not on for the demisters? The mirrors been loose for a few weeks now so maybe it might have happened then but the passenger one seems to be fine? Is it a case of getting a new mirror and stick it back onto the backing thing? This is quite confusing lol
Offline boxxer1973
« Reply #6 on: April 07, 2011, 08:02:38 pm »
demisters dont have to be on, Have you got the mirror switch on demist?
Offline dajackel12
« Reply #7 on: April 07, 2011, 08:46:49 pm »
hi mate
I didn't know about the mirror switch on demist? I've recently purchased the car so still trying to figure everything out, I thought to demist the side mirrors and the rear screen you just press the button on top of the ac button next to the recirculate button (on climatic)? Sorry to sound a complete noob.
How would I know if the switch is on? (i'm presuming your referring to the mirror adjuster which has the L-0-R options) sorry mate,
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #8 on: April 07, 2011, 09:07:33 pm »
Yes, it does have L O R but above those options at the 12 o clock position is a ~ symbol. This is the heated demist setting. If you've left the switch set at this point, the heaters are on. They are manual only & don't automatically shut off.
Offline dajackel12
« Reply #9 on: April 07, 2011, 09:58:27 pm »
crap, will need to check this out. I've not noticed it before but may not have looked at it closely but I should mention that I have an 54 plate 1.9tdi not a GTI? i'm presuming this doesn't change anything.
anyway, in regards to the mirror glass, will I have to purchase just the glass only with the sticky back or will I need other components as well? I'm assuming my current one won't just stick on?
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #10 on: April 07, 2011, 10:20:14 pm »
Mine did the exact same, i just stuck them on with velcro for a temp fix, ended up like that for 12months as i completly forgot untill i saw this thred.
Offline dajackel12
« Reply #11 on: April 07, 2011, 10:22:21 pm »
hi mate
yeah i just read that another member stuck it back on with that no more nails sticky pad,
Did the heated function work with the velcro? lol
Offline winrya
« Reply #12 on: April 07, 2011, 10:33:42 pm »
Happened to both of mine 12 months ago after I left the heated glass on :laugh:
Glued them back in place with superglue and been perfect ever since.  Went through the winter perfectly with heaters working as they should!
Offline dajackel12
« Reply #13 on: April 08, 2011, 10:16:49 pm »
Hi guys
Thanks for the replies, Well I checked my mirror adjustment switch this morning and it was on the demist setting! damn, Anyway popped down to local store and picked up some of that No more nails sticky tape and some super glue. Stuck it back on but I went abit over the top with the superglue and some drained to the bottom and it formed a small blob on the bottom of the mirror, It starts to catch when i try and tilt the mirror down, I figured I'll clean it up properly tomorrow.
Then a few hours later the adjustment thing stopped working, only the driver's side (repaired side) isn't working, Also the driver's door does not lock at all. Everything else is fine such as the electric windows etc. I'm hoping it may just be a fuse and nothing more serious. I will check the fuses tomorrow update here.
Offline dajackel12
« Reply #14 on: April 08, 2011, 11:30:35 pm »
Hi,
I know it's late but this thing was pi**ing me off so I checked the fuses and all of them are fine  :confused: what could be wrong with it now, this car has been nothing since problems since I got it. If anyone can help it would be greatly appreciated, I'm really considering getting rid of it!.
