Author Topic: Drivers side mirror came off -EDIT NOW DOOR WON'T LOCK+ADJUSTER NOT WORKING!  (Read 9557 times)
golfecho5
Re: Drivers side mirror came off today! need advise!
« Reply #15 on: April 08, 2011, 11:55:59 pm »
Someone whacked mine and something like this happened, best fix is Ebay and got new glass with wire for £10. Just plugs in and pops on, done job.
Offline dajackel12
Re: DOOR WON'T LOCK+ADJUSTER NOT WORKING! - Scanned - advise needed on scan
« Reply #16 on: April 09, 2011, 11:05:08 am »
Thanks for the reply mate, Yeah If there is a next time I probably would just try and get a used one from eBay,
I still can't figure this door lock thing out, It's like a module or something isn't working, So far the Driver's door does not lock with the keyfob (it locks with the blade), the Driver's side mirror doesn't adjust, (the passenger side seems to be adjusting fine), and also the little yellow light that come's on when you press the lock button on the driver's door doesn't come on when pressed, Also from the keyfob when i lock it then indicators don't blind but i'm presuming this is because the driver's door isn't locking.
Any ideas?
« Last Edit: June 14, 2011, 03:42:54 pm by dajackel12 »
Offline dajackel12
Just an update, Tried again checking fuses in just bear desperation but there all good. I can't actually hear the locking mechanism in the door when I press the fob. I think I may need to take the door card out now.
If anyone can help please post here as I am going mad over this now! argh
golfecho5
Total long shot, but a Merc ML we had did this and it drove me mad. Checked all the fuses and nothing but had the car plug in and checked and it was a relay that was faulty - worth a look because it's really annoying.
Offline dajackel12
Thanks for the info mate, I need to find someone with VAGCOM down in Leicester.
It is extremely annoying !
Thanks again
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Hi
Get the vag com done and post up the results
Cluster and Key coding
Location Great Yarmouth
Offline dajackel12
Thanks Eddie, Will do once I get it scanned.
Offline dajackel12
hey guys
just got it scanned and the results are below:
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Tuesday,14,June,2011,15:28:57:10074
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: xxxx   Mileage: 156410km/97188miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 CB    HW: 028 101 190 0
   Component: R4 1,9L EDC G000SG  6176
   Revision: 12345678    Serial number: VWZ7Z0D0586955
   Coding: 0000071
   Shop #: WSC 01279 785 00200
   VCID: 65C5B5A7D5F1
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021121
   VCID: 3A7F36DB0CCF
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1K0 820 047 CR
   Component: Climatic PQ35   081 0404
   Shop #: WSC 00000 000 00000
   VCID: 76E7E2EB7857
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000997349
   Coding: E4890F0600041800001400001400000000
   VCID: 3F8947CF17ED
   Part No: 1K2 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Part No: 1K0 955 559 M
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 00000
3 Faults Found:
01064 - Terminal 58d; Interior Dimming
            012 - Electrical Fault in Circuit - Intermittent
00988 - Lamp for Brake Light; Right (M10)
00987 - Lamp for Brake Light; Left (M9)
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
   Component: 02 AIRBAG VW8   023 0700
   Revision: 06023000    Serial number: 00385D0KG1L1
   Coding: 0012338
   Shop #: WSC 01268 785 00200
   VCID: 316D11F7D1B9
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 500 0030
   Coding: 0000022
   VCID: 306B14F3DAB3
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 951 G
   Component: KOMBIINSTRUMENT VDD 0716
   Coding: 0003403
   Shop #: WSC 00349 210 88197
   VCID: 2D550D87CD81
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 270010490800B0
   Coding: 3D0F0B40070003
   VCID: 295DF997F969
1 Fault Found:
01314 - Engine Control Module
            004 - No Signal/Communication - Intermittent
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0716
   VCID: 2D550D87CD81
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0148
   Coding: 0000052
   VCID: 306B14F3DAB3
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 G
   Component: EPS_ZFLS Kl.2       1301
   VCID: 306B14F3DAB3
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 80C802087F2D8505485BC69010
   Shop #: WSC 00873 210 91881
   VCID: 7BF1F3DF4375
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Part No: 1K0 907 719
   Component: Neigungssensor  003 0003
   Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Component: Tuersteuergeraet 09 0154
   Coding: 0000052
   VCID: 316D11F7D1B9
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 L
   Component: Radio BVX       010 0022
   Coding: 0040400
   VCID: 2F69178FC78D
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D550D87CD81
End   ---------------------------------------------------------------------
any ideas?
« Last Edit: June 14, 2011, 03:41:55 pm by dajackel12 »
Offline Richn83
  • -Given: 49
  • -Receive: 86
So nothing is showing up for the drivers side door module which controls all the items in the door (central locking, window winder control light for locking button mirror control etc)
If you still have the cable it would be worth doing an output test on the driver door control module as it will allow you to cycle through the functions of the controller to narrow down the error.
As a further comment you can adjust the heater timings for the rear window and the mirrors in one of the module in 1 minute increments, standard on my car was 10 minutes. (I cant remember which module right now as I was on a random look through long coding)
Offline dajackel12
thanks for the reply mate,
I've still got the cable but to be honest I don't know how to do the test on the driver control module  :ashamed:
i'll have a good look through the settings later today, is there any other tricks that I can do while i've got the cable?
thanks
Offline Richn83
  • -Given: 49
  • -Receive: 86
if you go into the driver door module, will be in the select module tab, then click on output test, it will then prompt you to click start and it will cycle through often with you pressing next as prompted on the screen, it will do things like flash the indicator, move mirror put window up and down cycle the locking mechanism.
Offline dajackel12
hey mate,
I forgot one thing, I was going through the settings before i performed that scan above and in one of the modules I found the code below, but I tried to clear the code then I performed the main scan, luckily before I cleared it I saved it! I'm pretty sure it's related to the door.
Tuesday,14,June,2011,15:24:34:10074
Control Module Part Number: 1K0 959 701 E
  Component and/or Version: Tuersteuergeraet 09 0148
           Software Coding: 0000052
            Work Shop Code: WSC 01279 785 00200
                      VCID: 306B14F3DAB3
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
        008 - Implausible Signal
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
sounds like the wiring could be causing the problem. check where the door loom plugs into the iterior loom
Offline Richn83
  • -Given: 49
  • -Receive: 86
hey mate,
                      VCID: 306B14F3DAB3
1 Fault Found:
That sounds like the error, this is what the ross tech Wiki says for that
http://wiki.ross-tech.com/wiki/index.php/00928
So as Eddie says you might have a loose cable somewhere.
« Last Edit: June 15, 2011, 11:29:59 am by Richn83 »
Offline dajackel12
hey guys
thanks for the advise, I'm going to check the wires later today, I'll keep this thread updated!
thanks again
