Author Topic: MK6 steering wheel on to a MK5  (Read 22067 times)
Offline hkp
Re: MK6 steering wheel on to a MK5
« Reply #15 on: September 16, 2011, 09:45:08 pm »
The loom on my MK6 air bag is 5K0 971 584 A which I assume is a multi function loom. So if I want to fit this non multifunction wheel to my non multi function Mk 5, does anyone know what loom I need? (part number)
Thanks again!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #16 on: September 16, 2011, 10:36:44 pm »
The part number is 5K0 971 584 is for a mk6 wheel without multifunction
I also have one if you want to swop
Cluster and Key coding
Location Great Yarmouth
Offline hkp
« Reply #17 on: September 16, 2011, 10:37:47 pm »
Yes please Eddie NL!
Offline hkp
« Reply #18 on: September 17, 2011, 02:38:39 pm »
I'm half suspecting that 5K0 971 584 (Mk.6 airbag harness non MF) is the same as 1KO 971 584 (A/K) (Mk5 Non MFSW) and 5KO 971 584A is the same as  1KO 971 584 C (L) which is the harness for Mk.5 MFSW.
So basically, the harnesses are the same between Mk 5 and Mk 6 and that you just need either a MF one or a non MF one.
Which leads me onto the next assumption that my Mk 5 harness will fit my Mk 6 wheel!!
(so I might not need to swap)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #19 on: September 17, 2011, 09:29:35 pm »
They are slightly different the mk6 has a tubular connector that fits to the base of the airbag. This is not on a MK5 loom
Offline OLLIE_JETTA_MK5
« Reply #20 on: September 20, 2011, 10:40:38 pm »
sorry to ask the same question
i have a 2007 jetta without mfsw and i want a rocco wheel . are you saying that i might already have the loom installed to have mfsw ?
so is it best to order a mk6.rocco wheel with mfsw that way all thing will work and ill have steering controls ?
Dubbin it since 2006
Offline hkp
« Reply #21 on: September 20, 2011, 10:46:21 pm »
Hey mate,
From what i can work out, if you don't have MFSW, you'll need a new steering wheel controller, and it'll need to be coded.
If you don't have MFSW, and you buy a mk6 non-MFSW, it'll bolt right on (if you get the correct airbag loom - I didn't, neither did Colin). Just make sure you insist the seller sells you the correct loom for Non-MFSW!
« Reply #22 on: September 20, 2011, 10:53:43 pm »
can't answer any tech questions but they do look good :happy2:
Offline hkp
« Reply #23 on: September 20, 2011, 10:57:15 pm »
 :notworthy:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #24 on: September 21, 2011, 06:36:10 am »
You will need
Scirocco MFSW inc airbag with mfsw loom
1K0 953 549CH Steering controller
« Reply #25 on: September 22, 2011, 06:51:50 am »
thanks so much mate !
« Reply #26 on: September 22, 2011, 07:07:01 am »
Looking good!  Do you know if it's possible to prize off the Vw badge in the middle?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #27 on: September 22, 2011, 09:44:51 am »
Isnt the badge attached to the airbag? I would be careful!
« Reply #28 on: September 23, 2011, 09:33:41 am »
The Vw golf 6 / Rocco flat bottomed looks alot better than the seat one but I dont know if the Seat airbag I the same shape :(
Offline hkp
« Reply #29 on: September 27, 2011, 09:11:36 pm »
Finally got mine done thanks to everyone here :)
Looks good no?
