Author Topic: RNS 510 Firmware update in Northern Ireland?  (Read 3934 times)
Offline No-fear
« on: April 13, 2011, 12:32:25 pm »
Hi there,
Just got an RNS510 LED version and alledgedly out of a 2010 Golf R.
I was checking out the Nav system and there isn't a postcode facility that i've found yet, I was told it had the V7 maps.
Looking to see if the firmware is the latest and if not, is there anyone in Northern Ireland on the forum who could update the system.
If not I'll be in Telford over the Easter weekend and could arrange to meet someone.
Also someone mentioned the secret menu to find the system details, any links?
Thanks for any help.
It's better to have Raced once in your life than be a Spectator for all of it.
Offline alexperkins
  • -Receive: 99
Re: RNS 510 Firmware update in Northern Ireland?
« Reply #1 on: April 13, 2011, 12:36:10 pm »
Ver C LED ones have to have the secret menu activated in VCDS by enabling Development Test Mode on Channel 51 in Adaptation
There will be postcodes on there, but you would need to have v7 for full postcode to work
Go into the address entry page, and try typing a postcode in, add the space, then the end and see if it works ie AB12 SPACE 3CD
Offline No-fear
« Reply #2 on: April 13, 2011, 12:45:12 pm »
Thanks Alex,
I continue to read the posts in this section of the forum.
I'll have to wait til the end of the week to check it out as my GTi is in getting a little colour coding to the side skirts and front and rear splitters.
Til then, I'll keep reading.
Offline alexperkins
  • -Receive: 99
« Reply #3 on: April 13, 2011, 12:47:13 pm »
No worries
Exciting time :) Always good to get some colour coding sorted  :happy2:
Offline No-fear
« Reply #4 on: April 13, 2011, 06:16:08 pm »
Alex,
I got the car back and the colour coding is what I wanted.
Back to the RNS, I tried entering a postcode into the address and when I had entered the first 4 it goes straight to an option menu listing the 5 number and the area, then you can add the address.
There is no way I can enter the 7 digits of the postcode.
So I guess I don't have a V7 Maps.
Also I tried to get up the hidden menu by holding the setup button, the radio menu appears and nothing else.
My car is an 08 and the unit is alledgedly out of an 2010 Golf R.
I'll have the unit out in the next two days to fit the aerial adaptor lead so I can read the markings on the unit. Is there anything I need to look for?
Thanks for your help so far.
  • -Receive: 291
« Reply #5 on: April 13, 2011, 06:19:32 pm »
There's no way you can tell which maps are on the unit.
You need two things - latest firmware and latest maps.
Offline alexperkins
  • -Receive: 99
« Reply #6 on: April 13, 2011, 06:27:50 pm »
As stealthwolf says, it suggests you are probably on V6 or earlier maps, so the only way to sort this is either enable the secret menu, or just upgrade the firmware and maps and problem solved  :happy2:
Offline No-fear
« Reply #7 on: April 13, 2011, 07:50:15 pm »
Thanks Lads,
Problem, I don't know of anyone on the forum based in Northern Ireland that has the capability to update the firmware and the maps.
I said earlier that I'll be in Telford over the Easter weekend for a competition and it could be possible to meet up with someone whilst i'm over, is there anyone close by that has the capablilty to help me out for beer tokens.
Thanks for your help.
Richard.
Offline alexperkins
  • -Receive: 99
« Reply #8 on: April 13, 2011, 07:51:25 pm »
Ill be in Birmingham on the 6th 7th and 8th if your still over!
Offline No-fear
« Reply #9 on: April 13, 2011, 07:53:26 pm »
Alex, I'll be there from the 21st evening and going back on the 25th April.
Thanks for the offer Alex, shame I can't take you up on it.
Offline No-fear
« Reply #10 on: April 14, 2011, 03:19:21 pm »
Had the head unit out again and found the software number.
Had to install the aerial adaptor lead, FM reception is now alot better.
details,
HW: H04
SW: 2680
I hope this sheds some light into updating the maps.
Offline alexperkins
  • -Receive: 99
« Reply #11 on: April 14, 2011, 03:20:49 pm »
Thats a Ver C on SW 2680 then, but apart from that I cant tell you what maps it has
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #12 on: April 14, 2011, 05:27:07 pm »
If it helps my RNS 510 LED is running this:
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H04 2680
   Revision: AB001001    Serial number: VWZ6Z7J9320057
   Coding: 080100400100001200
   Shop #: WSC 05314 000 00000
   ASAM Dataset: ------------------------- ------
   VCID: 2E59E6F2C091
You shouldn’t need to update the firmware as V7 map and postcode search will work O/K with 2680.  :happy2:
Offline No-fear
« Reply #13 on: April 14, 2011, 08:22:36 pm »
Thanks to you all,
Alex cheers for pointing me in the right direction.
Cheers,
Richard.
Offline Lyons
  • -Given: 18
« Reply #14 on: April 15, 2011, 11:07:55 am »
Is a map upgrade not a simple DIY anyway?
I feel your pain about NI though, theres a severe lack of people who can do such VCDS wizardry like fitting highlines etc over here!
