Author Topic: rns 510 question  (Read 1226 times)
Offline Modz
rns 510 question
« on: April 13, 2011, 10:38:22 pm »
I dont yet have a rns510 fitted to my car and after contacting the dealers they said i need version B but what would happen if I put a version C in?
Offline Kalpsn2000
  • -Receive: 56
Re: rns 510 question
« Reply #1 on: April 13, 2011, 10:40:30 pm »
What year is your car?
Your battery will drain if you have a can gateway older then a version K.
Offline apollo13
  • -Receive: 47
« Reply #2 on: April 13, 2011, 10:41:03 pm »
They are probably refering to battery drain issue ......
You could run C version on a modified firmware or change the can gateway to solve the drain issue.
Although a B version on a newer firmware will still give you drain.
So in short its not the 'version' thats the issue, its the firmware on the unit.
« Last Edit: April 13, 2011, 10:45:09 pm by apollo13 »
Offline Modz
« Reply #3 on: April 13, 2011, 10:47:05 pm »
it's a 2008 on a 58
Offline apollo13
  • -Receive: 47
« Reply #4 on: April 13, 2011, 10:51:02 pm »
You should be ok 2008 58 SHOULD have an L gateway so you SHOULD be ok.
You cannot be 100% sure though so you need a VCDS scan.
Later K gateways onwards won't give you the battery drain with any unit running any firmware  :happy2:
Offline Modz
« Reply #5 on: April 13, 2011, 10:53:52 pm »
thanks
  • -Receive: 291
« Reply #6 on: April 13, 2011, 10:56:08 pm »
I have a 2007 57 plate ED30 and it comes with an L-version can gateway.
