Author Topic: Cam Follower - what is it and whatsxproblems does it cause  (Read 3367 times)
Offline Boothy
« on: April 14, 2011, 08:14:17 am »
Noticed a few posts on the cam follower recently, in particular it being replaced. I'm just curious as to what exactly this does and what sort of effects does a faulty one create?
Would like to know what to look out for if its common problem.
Ta.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Cam Follower - what is it and whatsxproblems does it cause
« Reply #1 on: April 14, 2011, 08:34:27 am »
Some of the early engines had problems where the fuel pump piston would wear through the follower and impact directly on the cam-lobe eventually causing them to need replacing.
I think VAG changed the design of the lobe when the BWA engine came out (it may even have been earlier) and thus alleviated the problem somewhat.
I changed the follower on mine 4 times over 67k miles. One time I left it, due to work and forgetting, for 23k miles and it wasn't worn excessively.
However for the sake of a £25 part and 30mins work I used to change them as a matter of course. As the saying goes prevention is better than cure and I'd rather pay £25 every 10-15k miles than pay around £700 for a new Cam.
Some people have never changed them and they have been fine so I don't think it's anything to majorly worry about but it's defo worth checking especially if you hav an AXX engine.
Offline Boothy
« Reply #2 on: April 14, 2011, 11:06:02 am »
Would there be any tell tale signs if it was failing or had worn? Could it anyway be linked to poor fuel consumption by anychance?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #3 on: April 14, 2011, 12:53:19 pm »
I don't believe there are any warning signs until it's too late.  :scared:
Hence the reason I used to change mine periodically.
Offline Boothy
« Reply #4 on: April 15, 2011, 12:22:41 am »
Oh dear. Will get it checked as soon as then. Cheers bud  :happy2:
Offline lingenfelter
« Reply #5 on: May 16, 2011, 06:51:08 pm »
I change it every 5k miles approximatelly
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #6 on: May 17, 2011, 09:37:20 am »
.........there is,if you remove it you can see signs of wear.I think there is some sort of coating that shows signs.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #7 on: May 17, 2011, 10:17:00 am »
I assumed that Boothy was meaning warning signs from the normal day to day running of the car. So i was referring to the fact that there are no warning signs that indicate it is wearing unless you strip it apart. :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #8 on: May 17, 2011, 10:22:16 am »
The cam follower has a DLC (diamond like coating) which is black. If this starts to wear away to silver metal its time to replace as once the metal is exposed, it wears alot faster
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=dhpnp1c2eb3etat8udfg5ekgnr&/topic,19740.0.html
« Reply #9 on: May 17, 2011, 11:14:46 am »
How much is it to have these replaced?
Offline alexperkins
  • -Receive: 99
« Reply #10 on: May 17, 2011, 11:17:01 am »
£26ish+VAT for the part.
I did mine and steves the other day. Took 5 mins  :signLOL:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #11 on: May 17, 2011, 11:17:16 am »
Part costs £25 approx and 30mins work yourself :happy2:
« Reply #12 on: May 17, 2011, 11:17:55 am »
Is there a how to?  :smiley:
Offline alexperkins
  • -Receive: 99
« Reply #13 on: May 17, 2011, 11:19:16 am »
There is, but I havent got the link lol. I think its at the top of the How To section
Be prepared to get covered in petrol even with the pressure released  :signLOL:
« Reply #14 on: May 17, 2011, 11:20:49 am »
Not a job to be done whilst smoking a pipe then!  :signLOL:
