Author Topic: Connects2 or Parrot Multican with Parrot CK3100  (Read 2445 times)
Offline Fastmonkey
« on: April 15, 2011, 07:26:31 pm »
I'm thinking of getting a CK3100 with steering wheel controls and wondered if there was any difference in functionality between the 2 above systems and the MFSW features ?
MK5 R32 DSG Build thread   -  http://www.mk5golfgti.co.uk/forum/index.php/topic,23512.15.html
MK2 VR6 Vortech Charged
Offline alexperkins
  • -Receive: 99
Re: Connects2 or Parrot Multican with Parrot CK3100
« Reply #1 on: April 15, 2011, 09:09:05 pm »
Parrot generally is more updateable and has better phone support all round. I had a CK3100 in mine and it was very good.
Offline Norbreck21a
« Reply #2 on: April 15, 2011, 10:28:39 pm »
Alex, these are just ways of connecting the Parrot to the car. Both use the Parrot blue box.
I had the connects2 rig on my old Golf (with a CK3000 Evo) and it worked fantastically well, and was totally plug and play. Not a single wire (including a switched live) needed to be messed with. Just plugged it all in and it just worked and brilliantly.
Also, the connects2 brain (a small electronic box) is totally configurable depending if you have the earlier double phone buttons on your MFSW or the later style single ones. Also, as I purchased mine second hand, it didn't come with any instructions. I found that a quick email to quickconnects in the US was all it took, and the customer service from them (especially an individual called Howard) was nothing short of stunning.
The Parrot multican may well have the same functionality, but I have no experience of these.
« Last Edit: April 15, 2011, 10:30:14 pm by Norbreck21a »
Offline alexperkins
  • -Receive: 99
« Reply #3 on: April 15, 2011, 10:33:20 pm »
Sorry read it wrong! The connect two is more configurable and is direct plug and play as opposed to the parrot which requires you to tap into can high and can low
Offline Fastmonkey
« Reply #4 on: April 15, 2011, 11:19:55 pm »
Ok sounds like connects2 all the way then, so I need a connects2 box, a ck3100 and a VW quadlock harness and that will give me everything i need to fit it ??
