Author Topic: No sound when phone preparation takes or sends calls.  (Read 2824 times)
Offline Pinkfoot
« on: April 17, 2011, 12:31:58 am »
You may be able to help me! I have a 2008 Passat 2.0 tdi with ths problem: Car recognises my phone OK but when I make or receive a call even though the radio shows PHONE and the volume bar shows full volume I have no sound – only a slight hissing noise.
Here are the results of the VCDS Scan:
Monday,11,April,2011,11:33:42:44703
VCDS Version: Release 10.6.1
Data version: 20100831
Logic Automotive
Chassis Type: 3C0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 53 56 5D 62 72
77
VIN: WVWZZZ3CZ8E230065 Mileage: 45110km/28030miles
01-Engine — Status: OK 0000
02-Auto Trans — Status: OK 0000
03-ABS Brakes — Status: OK 0000
04-Steering Angle — Status: OK 0000
08-Auto HVAC — Status: OK 0000
09-Cent. Elect. — Status: OK 0000
15-Airbags — Status: OK 0000
16-Steering wheel — Status: OK 0000
17-Instruments — Status: OK 0000
19-CAN Gateway — Status: Malfunction 0010
25-Immobilizer — Status: OK 0000
42-Door Elect, Driver — Status: OK 0000
44-Steering Assist — Status: OK 0000
46-Central Conv. — Status: OK 0000
47-Sound System — Status: OK 0000
52-Door Elect, Pass. — Status: OK 0000
53-Parking Brake — Status: OK 0000
56-Radio — Status: OK 0000
5D-Operations — Status: OK 0000
62-Door, Rear Left — Status: OK 0000
72-Door, Rear Right — Status: Sporadic communication error 1000
77-Telephone — Status: Malfunction 0010
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 CL HW: 03L 907 309
Component: R4 2,0L EDC G000AG 2644
Revision: –H01— Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 84224 802 460520
VCID: 71E32B2D11DB
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 050 D HW: 02E 927 770 AE
Component: GSG DSG 081 1408
Revision: 09908010 Serial number: 00000703161506
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 132F41A54B07
Address 03: ABS Brakes Labels: 3C0-614-109-C4.lbl
Part No SW: 3C0 614 109 K HW: 3C0 614 109 K
Component: J104 C4 440 V2 0005
Revision: –020— Serial number: 00000785522915
Coding: 0001294
Shop #: WSC 05311 000 00000
VCID: 26490871E895
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 DA HW: 3C0 907 044 DA
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 63CF5165DB27
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008249785
Coding: E5808F0700041A00470A00000F00000000895DC35C00010000 0000000000
Shop #: WSC 00790 941 85030
VCID: 71E32B2D11DB
Part No: 3C2 955 119 B
Component: Wischer 280308 022 0601
Coding: 00046997
Shop #: WSC 00790
Part No: 1K0 955 559 AF
Component: RLS 110408 046 0204
Coding: 00208933
Shop #: WSC 00790
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__006 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP70PRR7
Coding: 0012342
VCID: 3B7FC9050317
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AR
Coding: 0001311
VCID: 6DDB375D0DE3
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 00810 209 64530
VCID: 26490871E895
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0841405C7
Coding: FD807F061026021003
VCID: 234F11659BA7
1 Fault Found:
01334 – Door Control Module; Rear Right (J389)
004 – No Signal/Communication – Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 42982 km
Time Indication: 0
Date: 2011.03.26
Time: 17:53:09
Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 00810 941 64586
VCID: 3973D30D092B
Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1132
Revision: 32008001 Serial number: 00000580788317
Coding: 0000757
VCID: 3B7FC9050317
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3669D8313835
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 00910A0001860E763004941570085F0B007801
VCID: 3973D30D092B
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 3C0 035 456 G HW: 3C0 035 456 G
Component: 08K Audioverst. 0006
Revision: 00003000 Serial number: 00000008128685
VCID: 244D12799EA9
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1132
Revision: 32008001 Serial number: 00000112088301
Coding: 0000756
VCID: 3C7DCA190619
Address 53: Parking Brake Labels: 5N0-907-801.lbl
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000431407
Coding: 0000057
VCID: 2953034DF98B
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 3C0 035 195 C HW: 3C0 035 195 C
Component: Radio PM6 012 0019
Revision: 00012000 Serial number: VWZ5Z7H1154911
Coding: 0012010
Shop #: WSC 05314 000 00000
VCID: 20451E698AB1
Address 5D: Operations Labels: None
Part No SW: 3C0 035 151 C HW: 3C0 035 151 C
Component: J738 011 0019
Revision: 00011000
VCID: 1835368952E1
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0308
Revision: 41004101 Serial number: 00000000292211
Coding: 0000208
VCID: 70E52E291AD1
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0308
Revision: 41004101 Serial number: 00000000294300
Coding: 0000208
VCID: 71E32B2D11DB
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 HW: 5N0 035 730
Component: Telefon 2510
Revision: 00011000 Serial number: 0000000070259
Coding: 0020035
VCID: E5CBCF7D5513
2 Faults Found:
00385 – Positive Output Audio Channel for Speech/Telephone
011 – Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 226
Mileage: 25780 km
Time Indication: 0
Date: 2010.07.12
Time: 10:32:36
00386 – Negative Output Audio Channel for Speech/Telephone
011 – Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 226
Mileage: 25780 km
Time Indication: 0
Date: 2010.07.12
Time: 10:32:36
End ———————————————————————
Offline alexperkins
  • -Receive: 99
Re: No sound when phone preparation takes or sends calls.
« Reply #1 on: April 17, 2011, 09:29:01 am »
Looks like the wiring has become disconnected for the Tel + and Tel - leads. What headunit and what phone prep?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: April 17, 2011, 11:10:17 am »
Just as it says really -
2 Faults Found:
011 – Open Circuit
011 – Open Circuit
It's telling you the +ve and -ve are open cct.
Have you done anything to the car lately?
Stu...
Offline alexperkins
  • -Receive: 99
« Reply #3 on: April 17, 2011, 11:12:58 am »
RCD500 and a Premium Bluetooth Kit then.
Late Night stu excuse my stupidity  :signLOL:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: April 17, 2011, 11:14:34 am »
Logic Automotive
Is http://www.logicautomotive.ie/ your company??   :happy2:
Stu...
Offline Pinkfoot
« Reply #5 on: April 17, 2011, 05:32:13 pm »
Head Unit is RCD 500 and Premium Bluetooth Preparation.
No, Logic Automotive is not my Company, I just went there for the Scan and forgot to delete the name.
It appears that the installation is a Retrofit as the cover on the BT under the Driver's seat is a different colour from the trim in the car.
It was in the car when I got it - even has a popup key pad on LHS of hazard flasher switch and phone cradle in centre console.
Two possibilities for it not working:
1. Connections broken
2. CAN gateway needs upgrading as the standard one may not be able to cope with the addition of the phone preparation.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: April 17, 2011, 08:39:05 pm »
If you have the popout keypad then it's likely the car would have been fitted with a phone kit from new but it would have been the less useful rSAP type.
Highly unlikely to be a Gateway issue IMHO, that appears to be fine.
Connections should be checked, I'd start by having a look behind the radio.  Previous owner may have had an RNS510 or something in and swapped out prior to selling.
Stu...
Offline Pinkfoot
« Reply #7 on: April 17, 2011, 08:57:26 pm »
rSAP suits me fine - I'm not into apps and iPhones. I don't think previous owner would have replaced RCD 500. All the answers I have had in the past few weeks point to a connection problem, so I will get my phone man to have a look and let you know how it goes.
Regards.
