Author Topic: coolent leak  (Read 2148 times)
Offline stevo
coolent leak
« on: April 18, 2011, 07:56:32 pm »
i know this is a bit of a grey area (could be anything) but have a leak DRIP around the front drivers corner just woundering if it could be the waterpump :confused:
any help would be great
Re: coolent leak
« Reply #1 on: April 18, 2011, 08:03:27 pm »
I had that in the past and turned out to be a leak from the washer bottle. A new washer sorted it.
Offline stevo
Re: coolent leak
« Reply #2 on: April 26, 2011, 01:09:59 pm »
well it has turned out to be the rad got the old one off now just woundering the best way to about refilling the water is there a way of doing this :happy2:
Offline alexperkins
  • -Receive: 99
Re: coolent leak
« Reply #3 on: April 26, 2011, 02:37:37 pm »
Fill through the expansion tank with a 50/50 coolant to water mix
Mill to the top of the hashed area, start the engine with the coolant cap still off
Turn the heat on the AC up to full heat and allow the engine to run for 5 mins or so - this will expel any air in the system
Check the level on the coolant after, and add more as necessary to the top of the hashed area
Offline stevo
Re: coolent leak
« Reply #4 on: April 26, 2011, 08:50:06 pm »
thanks for that god :happy2: now changing a rad is a job i never want to do again what a ball bag of a job
Offline stevo
Re: coolent leak
« Reply #5 on: April 27, 2011, 09:42:10 pm »
right well I have just noticed my front wipers have stopped working I have had the front end off to change the rad all leads are connected checked the fuses so not sure what else it could be any help would be great
Offline McKay88
Re: coolent leak
« Reply #6 on: April 27, 2011, 09:54:47 pm »
bit of an obvious one but is the bonnet closed properly?? if not the wipers wont work  :smiley:
Offline stevo
Re: coolent leak
« Reply #7 on: April 27, 2011, 10:12:41 pm »
ye checked that one lol
Offline alexperkins
  • -Receive: 99
Re: coolent leak
« Reply #8 on: April 28, 2011, 07:22:13 am »
Did you disturb the bonnet switch at all? Might be worth getting in on VCDS as I would expect it to flag an error
