Author Topic: Microphone from a VW prep kit  (Read 6867 times)
Offline Scotsman
  • -Given: 32
« on: April 19, 2011, 06:22:26 am »
I'll soon be installing a Parrot CK3000 with a quick connect harness - but would rather use the mic that's already installed with my VW phone prep kit (it's a 05 car).
The Parrot unit uses a mini 3.5mm jack connector - does anyone know whether the VW mic will fit, or does VW use a proprietory or difference connecter with the mic wiring? If it isn't a mini 3.5mm jack, could I do anything to convert it?
Many thanks
Richard.
Offline alexperkins
  • -Receive: 99
Re: Microphone from a VW prep kit
« Reply #1 on: April 19, 2011, 07:20:33 am »
The VW mic uses a proprietary connector, but theres nothing stopping you making an adapter up for it to work otherwise.
I was contemplating this in mine, but havent got round to it yet  :signLOL:
Offline Scotsman
  • -Given: 32
« Reply #2 on: April 19, 2011, 08:58:42 am »
I have no ability on that front at all - what would be involved? don't suppose you make adapter's up on commision do you?  :wink:
Offline Fastmonkey
« Reply #3 on: April 19, 2011, 09:16:42 am »
Could you just route the parrot mic up to the OEM location as an alternative ?
MK5 R32 DSG Build thread   -  http://www.mk5golfgti.co.uk/forum/index.php/topic,23512.15.html
MK2 VR6 Vortech Charged
Offline alexperkins
  • -Receive: 99
« Reply #4 on: April 19, 2011, 09:20:50 am »
I may make one up :P
yes you could, thats where mine is mounted though you can see the microphone; Ill get a photo
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #5 on: April 19, 2011, 09:21:51 am »
I believe the VW mic is in normal conditions active rather than passive not sure if this will have a bearing on using it with another kit?
Offline Scotsman
  • -Given: 32
« Reply #6 on: April 19, 2011, 09:22:10 am »
Yes, but guess I'm not sure how much is invovled in routing it plus could the OEM one be of better quality? (not sure).
Offline Scotsman
  • -Given: 32
« Reply #7 on: April 19, 2011, 09:22:57 am »
Ill get a photo
Thanks - would be useful to see.
Offline alexperkins
  • -Receive: 99
« Reply #8 on: April 19, 2011, 09:24:15 am »
I think you might be right Rich, but principally the microphone will be the same as such
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #9 on: April 19, 2011, 09:54:47 am »
I dont know if it will make a difference just though I would pipe in  :smiley:  I guess they all work the same diaphragm moving magnet through a coil of wire.
Offline alexperkins
  • -Receive: 99
« Reply #10 on: April 19, 2011, 09:57:19 am »
Indeed  :notworthy:
Thing is, to get a VW microphone working, you need a 3.5mm 2 pole plug at one end, a VW 2 pin socket at the other, so a fully custom loom
Offline Fastmonkey
« Reply #11 on: April 19, 2011, 01:46:50 pm »
If you use any kind of adaptor plug then it could affect mic quality.
I'm going to go to the effort of routing the parrot one up to the OEM location I think.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #12 on: April 19, 2011, 01:52:23 pm »
if the parrot one is the same as the fiscon unit then there is a thread around about modifying the foam bung in the OE slot to get the best results, alternatively Fiscon sell OE shaped mics with 3.5mm pins for 28 Euros or so if you dont fancy messing around.
Offline Golfgirl
« Reply #13 on: April 19, 2011, 02:35:23 pm »
I did that and had it in the internal light cluster but my callers couldn't hear me and said I was very muffled.  I had to move the mic outside the light cluster for them to be able to understand me.
FOR SALE!
Offline Fastmonkey
« Reply #14 on: April 19, 2011, 06:01:54 pm »
^^^ Did you do the foam modification ?
