Author Topic: IPOD doc won't play ipod....... Set up help required !  (Read 4555 times)
Offline alexperkins
  • -Receive: 99
Re: IPOD doc won't play ipod....... Set up help required !
« Reply #15 on: April 20, 2011, 12:12:27 pm »
I would say its a case of getting the new changer lead.
1T0 051 592A
Thats the code youll need for the dealer
Offline Fastmonkey
« Reply #16 on: April 20, 2011, 12:21:36 pm »
Ok cool i'll try and order one of them up. Is there any fitting guides anywhere ?
I'm going to get the MFD2 out soon as I'm going to do an amp and component and sub install so probably worth doing everything at once.
MK5 R32 DSG Build thread   -  http://www.mk5golfgti.co.uk/forum/index.php/topic,23512.15.html
MK2 VR6 Vortech Charged
Offline alexperkins
  • -Receive: 99
« Reply #17 on: April 20, 2011, 12:22:52 pm »
They come with instructions, but its as easy as plugging it in and just adding the brown earth wire to the ground point under where the ashtray site
Good plan
Offline Fastmonkey
« Reply #18 on: April 20, 2011, 03:43:32 pm »
Plugged the USB dock back in to double check it and all working fine.
Offline alexperkins
  • -Receive: 99
« Reply #19 on: April 20, 2011, 03:45:45 pm »
That is very odd. It either is..
The lead isnt compatible
OR
The iPod dock doesnt work
OR
The iPod has issues
Offline Fastmonkey
« Reply #20 on: April 20, 2011, 06:35:08 pm »
Yep it is odd !
So pretty sure the ipod works ok, i've been using it on an alpine HU in my other car, but I will borrow another one to make sure. Also I think one of my neighbours has a 6cd changer in their mk5 so thinking if I can persuade them to let me quickly test it that could troubleshoot all eventualities.
Offline Fastmonkey
« Reply #21 on: April 21, 2011, 03:11:34 pm »
No luck with the neighbours but a kind person off here lives locally and has offered up there ipod dock equipped car to test so hopefully get to the bottom of this tomorrow.
Checked with the dealer and the cable is £34..........  :sad1:
Offline alexperkins
  • -Receive: 99
« Reply #22 on: April 21, 2011, 03:14:46 pm »
Aye worth testing it out. Seems very odd you are having so many problems  :sad1:
Offline Fastmonkey
« Reply #23 on: April 23, 2011, 11:13:38 am »
Been thinking on this........... if the USB docker plays off the Aux and the Ipod and CD changer both play off the cd then it's got to be a different cable, correct me if I'm wrong but can't you have both a docker and an aux function ?
Testing Monday anyways......  :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #24 on: April 23, 2011, 11:27:35 am »
Aye you can have both. They use different pins on the same plug
Offline Fastmonkey
« Reply #25 on: April 23, 2011, 01:03:52 pm »
Ok I see, still substantiates my theory, but in that I have the wrong pins maybe......
Anyway all speculation, I just like trying to fix things !  :signLOL:
Offline Fastmonkey
« Reply #26 on: April 25, 2011, 10:02:41 pm »
Update........
Got a kind fellow forum member to come and test his working ipod dock with me today and his worked in my car as soon as it plugged in, and even charges my ipod. My docker I was sold doesn't work in his car, so conclusive proof it is a dud......... I've contacted the seller...........
Offline alexperkins
  • -Receive: 99
« Reply #27 on: April 25, 2011, 10:03:58 pm »
Ah fair play.glad we got to the bottom of it  :happy2:
Offline Fastmonkey
« Reply #28 on: May 06, 2011, 03:13:05 pm »
Replacement ipod docker turned up today and worked 1st time.........   :happy2:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #29 on: May 06, 2011, 03:42:39 pm »
Excellent news Mark will have a look for adapter tomorrow.
