Author Topic: OEM brake fluid  (Read 7209 times)
Offline Mako V12V
    • Astons, Porsches & Golf GTIs
OEM brake fluid
« on: April 21, 2011, 01:07:45 am »
Tried the search but not conclusive, so:-
What brand/spec of brake fluid does VWMD currently use and what quantity is required?
Not bothered about race/track fluid.
VW Golf Edition 30, Candy White, 3dr Manual. Plus a stunning Aston Martin V12 Vantage!
Offline Britishlion
  • -Given: 36
  • I have an eBay business !
Re: OEM brake fluid
« Reply #1 on: April 21, 2011, 07:40:22 am »
 Call trade parts specialists (tps) that is local to you
They will give you the most unto date VAG approved stuff ,
From memory I think it cost me £8 ! Might of been less though
While your on the the best GTI forum, get your wife to peruse my.
http://stores.ebay.co.uk/BRIGHTSPARKS-CONSULTANTS-WEB-STORE
Re: OEM brake fluid
« Reply #2 on: April 21, 2011, 09:58:29 am »
VW fluid is DOT4
Offline alexperkins
  • -Receive: 99
Re: OEM brake fluid
« Reply #3 on: April 21, 2011, 10:02:43 am »
Aye tis. I bought some from TPS yesterday
Offline Mako V12V
Re: OEM brake fluid
« Reply #4 on: April 21, 2011, 01:31:18 pm »
Thanks chaps.  :happy2:
So do TPS supply one "bottle" to do one change and what volume is required?
Offline alexperkins
  • -Receive: 99
Re: OEM brake fluid
« Reply #5 on: April 21, 2011, 01:33:22 pm »
It comes by the litre, and that should be enough for a change. I changed mine recently, and it was more than enough
Re: OEM brake fluid
« Reply #6 on: April 21, 2011, 03:30:26 pm »
If you use one of the one-man bleeding kits then I suggest you get 2 litres.
Offline coolhandluke
  • -Given: 28
Re: OEM brake fluid
« Reply #7 on: April 21, 2011, 03:44:54 pm »
Just on this topic how important is the recommended brake fluid change?
Mine has yet to be changed and the brakes still feel good.
Offline alexperkins
  • -Receive: 99
Re: OEM brake fluid
« Reply #8 on: April 21, 2011, 03:48:21 pm »
Very important.
Should be done every two years without fail
Brake fluid over time absorbs moisture and its compression ability reduces, meaning your brakes are slower and less firmly applied
Nasir
Re: OEM brake fluid
« Reply #9 on: April 21, 2011, 04:42:26 pm »
VW charged me £65 to do this, didn't know the fluid was only £8. WTF, how hard is it to change?
Offline Mako V12V
Re: OEM brake fluid
« Reply #10 on: April 21, 2011, 07:09:49 pm »
Thanks again. Vw Preston are doing my 3 year service and mot in a couple of weeks. My car also needs it's first brake fluid change and they've quoted £59 hence the desire to have done elsewhere at a reasonable cost!
Offline QD MBE
  • -Receive: 102
Re: OEM brake fluid
« Reply #11 on: April 21, 2011, 07:16:07 pm »
IMO once you have bought the fluid (Circa £10) and changed for £30-£40 labour (half hour at cheapest rate £60-80 Independent labour) I would just let VW do it.
It will be on the invoice, chances are properly done using a vacuum bleeder ( ie drawing the fluid through), you might save £10 getting it done elsewhere.
What is a £10?  Spend the £ and get it done with the service IMO.
Re: OEM brake fluid
« Reply #12 on: April 21, 2011, 07:16:39 pm »
Very important.
More importantly with heavy braking the trapped moisture in the fluid starts to boil leading to spongy brakes with loss of efficiency.
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
Re: OEM brake fluid
« Reply #13 on: April 22, 2011, 08:56:38 am »
£59 Brake Fluid Service=BARGAIN!!!
Offline Mako V12V
Re: OEM brake fluid
« Reply #14 on: April 22, 2011, 11:05:08 am »
Is it?
