Author Topic: HPFP's - Why did you choose yours?  (Read 15934 times)
Offline PDT
  • -Receive: 142
Re: HPFP's - Why did you choose yours?
« Reply #30 on: April 23, 2011, 03:55:49 pm »
yes Danish, spose you are right.
On my own car(s) I used autotch both times, purely down to cost and availability over the APR pump.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #31 on: April 23, 2011, 04:01:26 pm »
Even though i use APR myself, i have assisted a friend in getting an Autotech for his Passat as i find (after skimming the web) it to be near as good as the APR, only difference is it's not tested, so i follow you PDT  :drinking:
Over the top mod list ;o)
Offline PDT
  • -Receive: 142
« Reply #32 on: April 23, 2011, 04:05:04 pm »
I have a follower  :star:
  • -Given: 243
  • -Receive: 154
« Reply #33 on: April 23, 2011, 04:11:39 pm »
Offline George
« Reply #34 on: April 23, 2011, 04:12:09 pm »
I'll be going APR when the time comes, peace of mind is priceless for me  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #35 on: April 23, 2011, 04:47:06 pm »
Thanks to everyone for the opinions and info  :happy2:
Offline Rob GTI
« Reply #36 on: April 23, 2011, 09:42:22 pm »
As for the flatspot issue, I have seen this on stock, Revo tuned, Unbranded maps, Superchips and right accross the 2.0 TFSi engine range. I have also seen it with Autotech and APR equipped cars. I have been able to work around the flatspot with mapping in most cases but dont believe its a pump issue.
While trying to get to the bottom of my flat spot issue I switched the map off and still get it (although its less pronouced). At first I only noticed it intermitently (not long after pump fitted) and now all the time.
Do you think that the pump and the map (or one or other or combination of) has weaked my fuel pressure regulator. More importantly I guessing if that is the case and I understand yours and Alex's posts is that if I replace the valve with an RS4 version I may cure the flat spot. :popcornsoda:
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
  • -Given: 243
  • -Receive: 154
« Reply #37 on: April 24, 2011, 07:50:08 am »
RS4 valve might cure it, what brand of map are you running?  :smiley:
Offline Rob GTI
« Reply #38 on: April 24, 2011, 08:38:31 am »
REVO St 2.
Offline vRSAlex
  • -Receive: 253
« Reply #39 on: April 24, 2011, 10:07:32 pm »
Not 2+?
Follow AKS tuning on Facebook
Offline Rob GTI
« Reply #40 on: April 25, 2011, 10:48:04 am »
Not 2+?
I was advised that stage 2+ gives mostly a big increase in mid range torque rather than out and out top end power. That and I like the power to be as linear as possible, preserve my clutch and maintain traction as much as possible.  Although I may try it at some point to see what all the fuss is about. Just want to get this flat spot fixed and my twintercooler on first.
Offline vRSAlex
  • -Receive: 253
« Reply #41 on: April 25, 2011, 05:08:03 pm »
2+ gives a noticable increase throughout the rev range and the way the power is delivered can be setup with the revo software.
Well worth the upgrade to 2+.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #42 on: April 25, 2011, 06:35:47 pm »
Thanks for the opinions and thoughts everyone, I have made my choice
  • -Given: 243
  • -Receive: 154
« Reply #43 on: April 25, 2011, 06:42:40 pm »
 :congrats:  :congrats:
and the new car is??  :innocent:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #44 on: April 25, 2011, 06:52:15 pm »
^^^ You will find out when it's ready  :innocent:
