Author Topic: New Dash Insert  (Read 6494 times)
Offline busdriver
New Dash Insert
« on: April 25, 2011, 06:00:21 pm »
Hi guys, I have an EOS, not a golf but the members knowledge here is superb. I have a question if anyone can help please.
I am looking to upgrade my Instrument cluster, but I'm not sure which part to buy. I want full access to the convenience menus and display of NAV data from the RNS510 and also Bluetooth integration when installed.
My local VW dealer looked on his computer and told me I have a 1Q0 920 954 GX Z02 fitted and that I need a 1Q0 920 964 AX Z02 for the large display and functionality.
I have looked on my copy of ETKA 7.1 and the current part is listed as "dash panel insert for vehicles without  multi-function indicator". (although I do have a basic Multi function system operated from the wiper stalk. (On board computer). Is that the same as the multi function indicator or just classed as an on board computer?
The part recommended is listed as "dash panel insert for vehicles with multi function indicator". (Model PR-9Q1, which means "Multi-function display/on-board computer")
I have also found 1Q0 920 074 AX Z02, which is the same as the 964 AX version except Model Pr-9Q5, which means "Multi-function display with control")
All this terminology is confusing me (not difficult), so I was looking for a definitive explanation  of what I need please.
Regards
Pete
EOS 2.0 TDI Sport, Island Grey, Manual, Cichago 18" Alloys, Cruise Control, MFD2 Satellite Navigation, CD Changer, Parrot 3200-LS Bluetooth Hands-free Kit
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: New Dash Insert
« Reply #1 on: April 25, 2011, 06:13:40 pm »
the dealer is giving you the wrong part number
all EOS cars had a trip computer
so the lowline part number 954 is wrong
You probably have the midline 964, so the right one would end 974
To get the convenience options in the highline would also require you to have a MAX CCM
Cluster and Key coding
Location Great Yarmouth
Offline busdriver
Re: New Dash Insert
« Reply #2 on: April 25, 2011, 06:23:43 pm »
Thanks, I suspected something might be wrong.
BTW what is a MAX CCM. Is that the Central Electronic Control Module?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: New Dash Insert
« Reply #3 on: April 25, 2011, 06:28:27 pm »
The CCM controls the locking of the doors and the alarm
If you want to change the locking set up or have Rain Closing then you will need a max CCM
You will still have the Lights and Vision option which in the CECM
Offline apollo13
  • -Receive: 47
Re: New Dash Insert
« Reply #4 on: April 25, 2011, 06:36:46 pm »
 :signLOL:
Just amazes me how useless some dealers are......
I'd check with your local dealers/vw specialists about the cluster swap first to make sure they are willing to do it....
Offline busdriver
Re: New Dash Insert
« Reply #5 on: April 25, 2011, 06:54:49 pm »
Thanks for the info Eddie, maybe I won't bother with the locking options. I want the display primarily for the NAV and the Bluetooth. Maybe update it later.
With regard to the Midline. I have yet to find a definitive explanation as to what is the difference between, lowline, Midline and Highline.
The display type I want is
The one I have looks like
Any info would help
Offline DaveR77
    • UK-MKIVS.net
Re: New Dash Insert
« Reply #6 on: April 25, 2011, 07:00:25 pm »
http://www.vwcruise.com/93.html
Have a look at this, I plan on doing the same as I may be buying a car which has midline
Offline apollo13
  • -Receive: 47
Re: New Dash Insert
« Reply #7 on: April 25, 2011, 07:01:18 pm »
As Eddie said you have midline. Lowline looks the same but has no trip computer ect (Eos never had these)
Top pic is highline.
EDIT- £510!!! I bought and fitted my highline for £150  :signLOL:
Offline busdriver
Re: New Dash Insert
« Reply #8 on: April 25, 2011, 07:02:46 pm »
In have seen them but after adding VAT it all seems a little expensive. I was hoping to buy the dash and get someone local to code it for me. I have already bought a steering wheel, RNS 510 and am planning on getting a VW BT, and I would like them all coding together.
Offline busdriver
Re: New Dash Insert
« Reply #9 on: April 25, 2011, 07:04:57 pm »
Thanks Apollo. £150 quid, wow. Was that second hand. Thought there was a problem setting the mileage on a second hand unit, whereas a new unit is more simple. Any tips. Where did you get it from, EBAY?, or a breaker?
Offline apollo13
  • -Receive: 47
Re: New Dash Insert
« Reply #10 on: April 25, 2011, 07:05:13 pm »
Coding a cluster is not as straight forward as retrofitting other parts (unless your car is pre late 2005 or you have the skc code for the new cluster)
You need specialist equipment to copy the immobiliser info over to the new cluster.
TBH you'll need to go to someone like hazzydayz or find a dealer that is willing to do the swap as your car is later than late 2005.
« Last Edit: April 25, 2011, 07:09:00 pm by apollo13 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: New Dash Insert
« Reply #11 on: April 25, 2011, 07:07:50 pm »
only older cars have dash pods that can be done by forum members, as you need your code and the code of the cluster to be fitted. (although if you buy a new cluster it will come with the code)
Offline busdriver
Re: New Dash Insert
« Reply #12 on: April 25, 2011, 07:11:07 pm »
What determines an older cluster. As mentioned mine is 965 AX?
Offline apollo13
  • -Receive: 47
Re: New Dash Insert
« Reply #13 on: April 25, 2011, 07:12:58 pm »
Last number before the letters.
Only cluster ending in 970,971,972 can be done easily.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: New Dash Insert
« Reply #14 on: April 25, 2011, 08:11:04 pm »
this is interesting, as your part number is very new
I will give you 2 options
1Q0 920 975AX standard Highline
1Q0 920 985AX premium Colour Highline
Try and find a dealer to do the swap as your car is nearly new
