Author Topic: BIMECC 10 mm Hubcentric Spacer kits  (Read 1570 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« on: April 26, 2011, 10:13:41 am »
Hi Guys,
Want a set of 10mm spacers on the back of my car... has anyone used these and are they ok to use if fitted correctly?
http://cgi.ebay.co.uk/VW-GOLF-MK5-BIMECC-HUBCENTRIC-WHEEL-SPACER-KIT-10MM-/290510682560?pt=UK_Cars_Parts_Vehicles_Wheels_tyres_Trim_Nuts_ET&hash=item43a3c939c0
Dom
Diesel Daily Hack.
Offline bowie
Re: BIMECC 10 mm Hubcentric Spacer kits
« Reply #1 on: April 26, 2011, 07:48:49 pm »
Like he says in his description , be careful with the spigot (bearing housing) size on the rears. With this particular design of hub centric spacer you'll encounter the problem of the counterbore on the rear of the spacer being too shallow. You'll probably find that from 15mm up you'll be ok as this allows more depth on said counterbore. There's plenty on here who have 10mm on the rear but they must be the other design. I'm sure someone will put a pick up.
These are ok on the 4wd stuff though ( r32, s3).
Chris.
2010 Golf R DSG. Reflex. 3dr.
