Author Topic: Which CAN do I need for RNS510 C  (Read 12358 times)
Offline DaveR77
    • UK-MKIVS.net
« on: April 26, 2011, 01:42:53 pm »
I've just put a deposit down on an Edition 30 (Jan 2007) and want to buy an RNS510 version C. I assume my car will need a newer CAN to avoid any problems, which version should I get
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Which CAN do I need for RNS510 C
« Reply #1 on: April 26, 2011, 01:50:15 pm »
this one is the newest one on ebay.de atm, but i have the AH revision (made in march 2010)
http://cgi.ebay.de/Audi-Steuergerat-Gateway-1K0-907-530-AF-Gateway-Temic-/130504976331?pt=Autoteile_Zubeh%C3%B6r&hash=item1e62b3e7cb
Over the top mod list ;o)
Offline DaveR77
    • UK-MKIVS.net
« Reply #2 on: April 26, 2011, 01:55:03 pm »
cheers, is L the lowest needed for the RNS, best check what I have first before ordering a new one!
Offline alexperkins
  • -Receive: 99
« Reply #3 on: April 26, 2011, 02:31:09 pm »
K is the lowest needed not L, though not all Ks are suitable.
Its likely yours will already have a K
Youll need to scan your CAN Gateway with VCDS and post up the SW and HW revisions of it.
Mine had a K and it was absolutely fine.
  • -Given: 243
  • -Receive: 154
« Reply #4 on: April 26, 2011, 02:34:39 pm »
I had a K in mine and it wasn't fine  :wink:
Offline alexperkins
  • -Receive: 99
« Reply #5 on: April 26, 2011, 02:35:12 pm »
What build month was yours danish?
  • -Given: 243
  • -Receive: 154
« Reply #6 on: April 26, 2011, 03:23:44 pm »
12 month 2005  :smiley:
Offline alexperkins
  • -Receive: 99
« Reply #7 on: April 26, 2011, 03:26:39 pm »
Ah early then
2007 cars are generally ok on a K  :happy2:
Offline RagingKileak
« Reply #8 on: April 26, 2011, 03:28:35 pm »
I'm also wondering about this whole CAN Gateway thing. I have a 2007 Ed 30 (dunno what build or exact month as I am at work) and I want to be sure I won't get stupid issues following fitting BT and RNS510 etc.
Don't have any way of scanning though, sigh.
Where does the CAN Gateway live? Is it a DIY swap or need coding/hard to locate?
Matt
Offline DaveR77
    • UK-MKIVS.net
« Reply #9 on: April 26, 2011, 03:31:18 pm »
Right, bought the RNS, i'll give it a go before changing the CAN
Offline alexperkins
  • -Receive: 99
« Reply #10 on: April 26, 2011, 03:32:14 pm »
Can Gateway is hidden behind the relay/fuse box.
Accessible by removing the wiper motor and the access panel beneath it
Offline Resonance
  • ED 30 Steel Grey DSG
« Reply #11 on: April 26, 2011, 05:30:06 pm »
My eyes are stuck to this thread, I have a Feb 2007 Edition 30 and want to upgrade to a RNS510 at some point and this thread should answer my question about the CAN gateway issues  :laugh:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #12 on: April 26, 2011, 05:38:24 pm »
Do you take the back wheels off when you top up the oil or is it just CAN gateways you like to take your time over  :evilgrin:
The Gateway is accessible from inside the car.  :happy2:
Stu...
Offline apollo13
  • -Receive: 47
« Reply #13 on: April 26, 2011, 05:39:47 pm »
Or just get to it above the pedals.....
Unless you have an early car and then they're sometimes behind the ashtray/cubby area.
EDIT-Stu beat me to it  :signLOL:
Offline DaveR77
    • UK-MKIVS.net
« Reply #14 on: April 26, 2011, 05:49:57 pm »
I'll let you know, probably won't get the unit til next week thanks to the wedding so i'll fit it next weekend
