Author Topic: Which CAN do I need for RNS510 C  (Read 12433 times)
Offline alexperkins
  • -Receive: 99
Re: Which CAN do I need for RNS510 C
« Reply #15 on: April 26, 2011, 06:15:15 pm »
Can Gateway is hidden behind the relay/fuse box.
Accessible by removing the wiper motor and the access panel beneath it
Do you take the back wheels off when you top up the oil or is it just CAN gateways you like to take your time over  :evilgrin:
The Gateway is accessible from inside the car.  :happy2:
Id have given you £50 quid if you could get to my can gateway. Some retard had cable tied it to the back of where the access plate is
There was absolutely no way in hell I could have got in there, be it from the top or via the pedals - believe me I tried.
I dont take the wheels off for oil top ups, but I take the exhaust off when I change the spark plugs though  :signLOL:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #16 on: April 26, 2011, 09:25:13 pm »
Or just get to it above the pedals.....
Unless you have an early car and then they're sometimes behind the ashtray/cubby area.
EDIT-Stu beat me to it  :signLOL:
On some cars it is near the bulkhead
http://www.r32oc.com/tutorials-guides/30166-canbus-gateway-location-removal.html
Cluster and Key coding
Location Great Yarmouth
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #17 on: April 26, 2011, 09:28:33 pm »
I can get to it from the front even in that location, not easy granted but less hassle than going in through the scuttle.
Stu...
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #18 on: April 30, 2011, 02:15:36 pm »
What HW and SW versions on a K gateway have been proven to work?
Got a car with the following version : -
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 060107F1001787
   Coding: 3F3F034007001003
   Shop #: WSC 00066 000 00000
   VCID: 2F69457DC5DD
No fault code found.
Offline DaveR77
    • UK-MKIVS.net
« Reply #19 on: May 05, 2011, 06:11:07 pm »
K is the lowest needed not L, though not all Ks are suitable.
Its likely yours will already have a K
Youll need to scan your CAN Gateway with VCDS and post up the SW and HW revisions of it.
Mine had a K and it was absolutely fine.
Mine is the following - same as SteveP
   Revision:   H04 02    Serial number: 281106F1001231
   Coding: 3F0F034007000001
   Shop #: WSC 01287 785 00200
   VCID: 2F671974C78D
« Last Edit: May 05, 2011, 06:13:56 pm by DaveR77 »
Offline alexperkins
  • -Receive: 99
« Reply #20 on: May 05, 2011, 06:47:55 pm »
I believe you have to have HW with a 21 signature for it to work - thats what mine had and it was a later K revision
Whats the build date of yours?
Best thing to do is try it and see
Offline DaveR77
    • UK-MKIVS.net
« Reply #21 on: May 05, 2011, 07:03:33 pm »
Jan 07, not gonna do any harm trying  :scared:
Offline alexperkins
  • -Receive: 99
« Reply #22 on: May 05, 2011, 07:05:47 pm »
You *might* be ok, but its possible you wont be as March 07 was when the later K units were installed
Worth a shot  :happy2:
Offline DaveR77
    • UK-MKIVS.net
« Reply #23 on: May 05, 2011, 07:14:23 pm »
Are there any other signs apart from draining the battery, I think I read it switches itself off randomly too?
Offline alexperkins
  • -Receive: 99
« Reply #24 on: May 05, 2011, 07:22:58 pm »
Symptoms....
It wont show the Welcome to Volkswagen boot screen after it has booted the first time
It'll drain the battery
It can randomly restart
It can also switch off
Offline DaveR77
    • UK-MKIVS.net
« Reply #25 on: May 06, 2011, 09:02:17 am »
Gonna buy one to save the hassle, is AH the latest? How much are they from the dealer?
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #26 on: May 06, 2011, 09:06:01 am »
To expensive from the dealer, in Denmark i was quoted 150£ for one, about half price on ebay.de  :smiley:
Over the top mod list ;o)
Offline DaveR77
    • UK-MKIVS.net
« Reply #27 on: May 06, 2011, 09:42:13 am »
The AA+ ones are about £110 in delivery on ebay.de at the moment
Offline alexperkins
  • -Receive: 99
« Reply #28 on: May 06, 2011, 11:07:22 am »
http://cgi.ebay.co.uk/CANGATEWAY-1K0907530AA-CAN-GATEWAY-RNS-510-RCD-510-/170601532805?pt=UK_AudioTVElectronics_GPSSystems_GPSSystems&hash=item27b8a4cd85#ht_3131wt_1141
When I ordered that, I received a 7N0 variant which is out the new EOS and is bang up to date
Remember, you only need a gateway newer than a K so an L onwards will work a treat. Theres little advantage to having the latest revision in our cars
Offline DaveR77
    • UK-MKIVS.net
« Reply #29 on: May 06, 2011, 12:37:50 pm »
ta, ordered one of those, dealer said £158 for an AF, AH wasn't on his system
