Author Topic: Which CAN do I need for RNS510 C  (Read 13706 times)
Offline alexperkins
  • -Receive: 99
Re: Which CAN do I need for RNS510 C
« Reply #30 on: May 06, 2011, 12:44:38 pm »
You will need 10.6.3 or higher VCDS to code this gateway btw just to make you aware  :happy2: These are the newer gateways that user the Installation List instead of Long Coding to set the configured options
Offline DaveR77
    • UK-MKIVS.net
« Reply #31 on: May 06, 2011, 12:54:56 pm »
Yep, I've got the latest VCDS  :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #32 on: May 06, 2011, 01:06:41 pm »
Then its happy days  :wink:
Offline DaveR77
    • UK-MKIVS.net
« Reply #33 on: May 07, 2011, 10:51:29 am »
Symptoms....
It wont show the Welcome to Volkswagen boot screen after it has booted the first time
It'll drain the battery
It can randomly restart
It can also switch off
OK, RNS is fitted and working  :happy2:
Should it show the welcome screen everytime I turn it on? It doesn't at the moment
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #34 on: May 07, 2011, 10:52:27 am »
Only after 1 hour of the ignition being off, my revision K gateway appears to be working fine.
Offline DaveR77
    • UK-MKIVS.net
« Reply #35 on: May 07, 2011, 10:54:39 am »
cheers, so if I go back in an hour or so and it shows the welcome screen it should be okay?
Offline DaveR77
    • UK-MKIVS.net
« Reply #36 on: May 07, 2011, 12:29:41 pm »
Well it showed the welcome screen  :happy2: fingers crossed!
Offline DaveR77
    • UK-MKIVS.net
« Reply #37 on: May 07, 2011, 02:04:50 pm »
Does anyone know what setting I need to set in VCDS to get Nav on the MFD? I've added Navigation (37) to the CAN gateway, I thought that was all that was needed. There's no audio on the MFD either
« Last Edit: May 07, 2011, 02:26:54 pm by DaveR77 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #38 on: May 07, 2011, 07:09:17 pm »
Do you have a Full height MFD (Highline)?
If you do, then check the coding in the RNS and see if BAP is ticked. If it is untick it and reboot
Cluster and Key coding
Location Great Yarmouth
Offline DaveR77
    • UK-MKIVS.net
« Reply #39 on: May 07, 2011, 07:45:10 pm »
Yeah highline, I can't find bap tickbox, is it under navigation coding?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #40 on: May 07, 2011, 07:54:21 pm »
Go into navigation > Coding > Long Coding
Restart the RNS after making changes
Offline DaveR77
    • UK-MKIVS.net
« Reply #41 on: May 08, 2011, 06:38:07 pm »
I think I must be blind! Does anyone have a screenshot of what I should be unticking?
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Offline alexperkins
  • -Receive: 99
« Reply #43 on: May 08, 2011, 09:34:23 pm »
Its on the last byte in the Long Coding on 37 - Navigation
Notice at the bottom where it says BAP - you need to untick this
Offline DaveR77
    • UK-MKIVS.net
« Reply #44 on: May 09, 2011, 06:58:32 pm »
Done that but still nothing on the dash, is there anything else I need to do?
