Author Topic: Dual mass flywheel Q/problem???  (Read 7762 times)
kierongti
« on: April 27, 2011, 05:31:00 pm »
Hi all, I had the car serviced today and asked them to check a noise that I could here from the engine... When you are in the car with doors closed, blowers off and all is quiet I can hear a tapping/knocking type sound when engine is running on idle.. It is a lower sounding tone than that of the injectors.. The vag garage say it isn't the 'bottom end'
Basically I am wondering what the DMF sounds like when it's on it's way out? Or any other suggestions from other people's previous experience.. Thanks all...
Offline s3dubbin
Re: Dual mass flywheel Q/problem???
« Reply #1 on: April 27, 2011, 05:36:31 pm »
I am no expert but i would imagine that a dmf on its way out would sound like a smf when fitted, like a rattling unbalanced noise? Somebody in the know will come along and help you out soon. Stevie.
kierongti
« Reply #2 on: April 27, 2011, 07:54:41 pm »
it is a sort of wobbly unbalanced sounding rattle if that makes sense... engine bay has been checked and all is bolted tight etc etc.. :stupid:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #3 on: April 27, 2011, 09:27:57 pm »
Is it like a deep chattering sound coming from gearbox area? Both my current ed30 and my r32 have had a similar noise so assume it's normal...
Diesel Daily Hack.
Neil
« Reply #4 on: April 27, 2011, 09:57:06 pm »
When my DMF went it sounded like a consistant metalic rattle / ticking which only occured when the car was warmed completely up, at first I thought it was just a heat sheild but no how wrong I was. hth  :smiley:
Dealer wouldn`t do anything for me regarding the DMF and I`d had the car less than a month.
Nor was the dealer / VW customer services interested in the ESP failure. I persisted with this and only paid a minimal fee, well minimal to having the DMF replaced myself  :laugh:
kierongti
« Reply #5 on: April 27, 2011, 09:58:10 pm »
it could be?? difficult to say... would have to hear another engine with a noisey DMF....  :confused:
kierongti
« Reply #6 on: April 27, 2011, 10:00:48 pm »
think mine is only there once warm.... why do these parts go wrong on a 60k engine?? thought vw were supposed to be good?
Offline daboy3000
  • MKV GT TDi
« Reply #7 on: April 28, 2011, 11:40:08 am »
My flywheel is on its way out, I get no noise but sometimes a lot of seat wobble.
Offline d.mellor
« Reply #8 on: April 28, 2011, 11:53:12 am »
Next time you get back from driving so the engine has warmed up, stick the handbrake on and put the car in neutral with the clutch out. (blowers and radio off etc) just sit in your seat and if you can feel the car juddering slightly put your clutch in, if the juddering stops it probably the dmf.
Im no expert put this is what i got told to look out for when buying my mk5.
Offline daboy3000
  • MKV GT TDi
« Reply #9 on: April 28, 2011, 11:55:39 am »
Putting the clutch in doesn't make a difference, if you put it in gear and put a little load on to it, then it stops.
Offline titchy
« Reply #10 on: April 28, 2011, 04:19:55 pm »
i had a slight knocking noise at idle it turned out to be coming from air con when air con is off the noise goes dealer said its normal nothing to worry abouy been like it since i got the car a year ago the noise  was coming from low downbehind dash
